Wired Intelligent Edge
  • 1.  port-channel lacp fallback on HP Procurve
    Posted Aug 08, 2018 08:08 AM
    Hello All. Is there such option on HP Procurve swithes? I need it for PXE booting to work
    Thanks in advance
    #Trunk
  • 2.  RE: port-channel lacp fallback on HP Procurve
    Posted Aug 09, 2018 04:22 AM
    Hello
    You can use following command in the switch:
    Here you create a port-channel with port 1/1 and 1/2, you name it trk1 and you enable lacp.
    trunk 1/1,1/2 trk1 lacp
    If you want to allow vlans on this port-channel, you can't use these ports anymore, but you will need to use trk1, for example.
    vlan 10
    tagged trk1
  • 3.  RE: port-channel lacp fallback on HP Procurve
    Posted Aug 09, 2018 04:32 AM
    Hello, thank you for answer, but i mean i need this interfaces as trunk, and trunk does work, but at first one of this interfaces should work as standalone link for PXE boot (PXE can't use trunk) and when system is booted and lacpbdu is in operation again, trunk should be up again. Other vendors have for example this command port-channel lacp fallback to work for this behavior.
    So if interface doesn't receive lacpbdu it should not block the port, but works as standalone interface.
