I have a customer with 2 HP 1810-24G V2 and 2 Hp 1810-48G switches trunked to a 2530-24G switch.
On the 18xx switches they are getting constant disconnect/reconnect of ports within a few seconds..
724 Info Mar 11 07:02:30 NIM Interface 7 is Link Down
725 Info Mar 11 07:02:34 NIM Interface 7 is Link Up
726 Info Mar 11 07:02:35 NIM Interface 7 is Link Down
727 Info Mar 11 07:02:38 NIM Interface 7 is Link Up
728 Info Mar 11 07:02:49 NIM Interface 7 is Link Down
729 Info Mar 11 07:02:52 NIM Interface 7 is Link Up
734 Info Mar 11 08:22:39 NIM Interface 18 is Link Up
735 Info Mar 11 08:22:41 NIM Interface 18 is Link Down
736 Info Mar 11 08:22:45 NIM Interface 18 is Link Up
737 Info Mar 11 08:22:57 NIM Interface 18 is Link Down
738 Info Mar 11 08:23:01 NIM Interface 18 is Link Up
739 Info Mar 11 08:26:09 NIM Interface 2 is Link Down
740 Info Mar 11 08:26:14 NIM Interface 2 is Link Up
741 Info Mar 11 08:26:15 NIM Interface 2 is Link Down
742 Info Mar 11 08:26:18 NIM Interface 2 is Link Up
743 Info Mar 11 08:26:31 NIM Interface 2 is Link Down
744 Info Mar 11 08:26:34 NIM Interface 2 is Link Up
745 Info Mar 11 08:55:32 NIM Interface 43 is Link Down
746 Info Mar 11 08:55:37 NIM Interface 43 is Link Up
747 Info Mar 11 08:55:39 NIM Interface 43 is Link Down
748 Info Mar 11 08:55:42 NIM Interface 43 is Link Up
749 Info Mar 11 08:55:55 NIM Interface 43 is Link Down
750 Info Mar 11 08:55:58 NIM Interface 43 is Link Up
751 Info Mar 11 09:01:51 NIM Interface 45 is Link Down
752 Info Mar 11 09:01:55 NIM Interface 45 is Link Up
753 Info Mar 11 09:01:58 NIM Interface 45 is Link Down
754 Info Mar 11 09:02:01 NIM Interface 45 is Link Up
755 Info Mar 11 09:02:13 NIM Interface 45 is Link Down
756 Info Mar 11 09:02:16 NIM Interface 45 is Link Up
757 Info Mar 11 09:04:33 NIM Interface 20 is Link Down
758 Info Mar 11 09:04:38 NIM Interface 20 is Link Up
759 Info Mar 11 09:04:38 NIM Interface 20 is Link Down
760 Info Mar 11 09:04:41 NIM Interface 20 is Link Up
761 Info Mar 11 09:04:54 NIM Interface 20 is Link Down
762 Info Mar 11 09:04:57 NIM Interface 20 is Link Up
As you can see they happen within a few seconds and happen on a varity of equipment (HP PC's, HP notebooks, Printers). I have a support case logged and after 3 firmware upgrades later they are blaming everything but the switcehs. I have had the cabling tested with a Fluke DSX and vertified to Cat5e, upgraded firmware/drivers on PC's, changed patch leads and even changes the switches but i get the same disconnects.
Anyone got a simular problem? Anyone got any idea's?
HP are going down the spanning tree route and blaming the topology changes on another switch (this i am working on) but i don't see how spanning tree can be affecting so many devices on switches that don't support spanning tree?
Please help!
Kris
#link#disconnect#Interface#1810-48g#down#interfacelinkdown#faulty#1810#1810-24g
