Wired Intelligent Edge
Port Isolation (Wired Guest Network)
  • 1.  Port Isolation (Wired Guest Network)
    Posted Mar 06, 2017 02:21 PM
    I am using an Aruba 3810M switch. I am trying to create a VLAN that allows users to connect hardwired as guest. I want them to have the port isolation to the internet as if they were on a WLAN Guest network. Anotherwords, the device plugged into Port1 cannot see Port2, etc... There are 1300 ports in the building. Creating a seperate VLAN is out of the question. I have attempted to use the Private Vlan feature. It did not work as I hoped, or my configuration was incorrect. Can someone point me in the right direction to get this started?
  • 2.  RE: Port Isolation (Wired Guest Network)
    Posted Mar 07, 2017 06:35 AM
    you can use "isolate-list" feature on the vlan. Isolate-list feature creates a list of isolated ports for the VLAN. Traffic received on isolated ports will not be forwarded to other isolated ports in the VLAN. Traffice will be forwarded  only to non-isolated ports on that vlan.For example if ports a1-a23 is part of vlan 1,and if "isolate-list" is created with  ports a1-a22, then ports a1-a22 will not be able to talk to each other. only port a23 can talk to a1-a22.
    HP-Switch-5406Rzl2(vlan-1)# isolate-list a1-a22
  • 3.  RE: Port Isolation (Wired Guest Network)
    Posted Mar 07, 2017 06:38 AM
  • 4.  RE: Port Isolation (Wired Guest Network)
    Posted Mar 07, 2017 06:40 AM
    Thank You! I will try that on my “test floor” as soon as I get in this morning.
  • 5.  RE: Port Isolation (Wired Guest Network)
    Posted Mar 08, 2017 11:57 AM
    That worked wonderfully! Thanks so much for the input!
  • 6.  RE: Port Isolation (Wired Guest Network)
    Posted Jul 02, 2020 01:05 AM
    What is Port Isolation referred to actually whether Port Security or Private VLAN and is it supported on Aruba OS-CX Switches?
  • 7.  RE: Port Isolation (Wired Guest Network)
    Posted Jul 02, 2020 01:32 AM
    Dear All, any update would be helpful as it is too urgent
