Q. I'm confused. Gi1/0/9 and Gi2/0/9 are internal ports on the 6125 blade switches.
A. You are correct. I would expect those port to have the mac-address associated with what I see in the OBA and Vmware.
Q.I would expect a bladeserver to be connected on its internal networkdevices.
A. yes I see the mapping on the OBA for the C7000 where it ties them to the HP 6125G Insterconnect switch.
when I run a display interface Gi1/0/9 I get the following:
<BS3_iSCSI_6125G>display interface Gi1/0/9
GigabitEthernet1/0/9 current state: UP
IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 2c23-3aa8-d5e3
Description: to DXBL9
Loopback is not set
Media type is not sure,Port hardware type is No connector
1000Mbps-speed mode, full-duplex mode
Link speed type is force link, link duplex type is force link
Flow-control is not enabled
The Maximum Frame Length is 9216
Broadcast MAX-ratio: 100%
Unicast MAX-ratio: 100%
Multicast MAX-ratio: 100%
Allow jumbo frame to pass
PVID: 51
Mdi type: auto
Port link-type: access
Tagged VLAN ID : none
Untagged VLAN ID : 51
Port priority: 0
Last clearing of counters: Never
Peak value of input: 13 bytes/sec, at 2017-06-06 14:34:54
Peak value of output: 64 bytes/sec, at 2017-07-19 11:02:25
Last 300 seconds input: 0 packets/sec 0 bytes/sec 0%
Last 300 seconds output: 0 packets/sec 15 bytes/sec 0%
Input (total): 97047 packets, 9604571 bytes
0 unicasts, 82 broadcasts, 96965 multicasts, 0 pauses
Input (normal): 97047 packets, - bytes
Input: 0 input errors, 0 runts, 0 giants, 0 throttles
0 CRC, 0 frame, - overruns, 0 aborts
- ignored, - parity errors
Output (total): 226881 packets, 60408870 bytes
35 unicasts, 45063 broadcasts, 181783 multicasts, 0 pauses
Output (normal): 226881 packets, - bytes
Output: 0 output errors, - underruns, - buffer failures
0 aborts, 0 deferred, 0 collisions, 0 late collisions
0 lost carrier, - no carrier
This shows its got a diffrent mac address.
How do I find the mac-address that is assocated with the card for Interconnect's 3 and 4?
