Comware
Port mirroring on a HPE 1920-24G-PoE+ wont work
  • 1.  Port mirroring on a HPE 1920-24G-PoE+ wont work
    Posted Sep 25, 2019 04:09 AM
    Hi there,
    due to a tricky wifi problem I have to dump the traffic out, which passed the core switch (HPE 1920-24G-PoE+) to the router.
    To do so, I added a "Mirroring Group ID" and added the uplink port to the router (GE1/0/24) as "Monitor Port" and set a  "Mirror Port" (GE1/0/23) too. You might have a look at the screenshot https://ibb.co/5vtb0Pr.
    But if I attach my laptop to GE1/0/23 and start wireshark, I only see ARP and upnp broadcasts. No TCP or UDP traffic. Thats very weird.
    Additional info:
    Swtich is running software version 5.20.99 Release 1121
    Any ideas are welcome!
    #Network
    #mirroring
    #Dump
    #traffic
    #Port
  • 2.  RE: Port mirroring on a HPE 1920-24G-PoE+ wont work
    Posted Sep 25, 2019 05:45 AM
    Shame on me!
    I was on the wrong trip. "Mirror Port" is the source and "Monitor Port" is the port, where the traffic is mirrored to.
    After I switched both ports, the problem is solved.
