Wired Intelligent Edge
Port mirroring on Aruba 2540
  • 1.  Port mirroring on Aruba 2540
    Posted Jul 16, 2019 10:53 AM
    Dear Community,
    i got a short question, can you help me to configure port mirroring on my Aruba 2540. I simply want to get all the traffic copied form for example port 5 to port 24.
    Thanks ahead.
    #2540
  • 2.  RE: Port mirroring on Aruba 2540
    Posted Jul 16, 2019 01:26 PM
    can you try with below configuration
    switch(config)# mirror 1 port 24
    switch(config)# interface 5 monitor all out mirror 1
    Best Regards,
    Sureshreddy
  • 3.  RE: Port mirroring on Aruba 2540
    Posted Jul 17, 2019 03:54 AM
    Dear
    thanks for your quick answer, it's not possible to execute the first command on my device.
    Do you have any other ideas?
    FYI:
    Firmware Version: YC_16_08_0001
  • 4.  RE: Port mirroring on Aruba 2540
    Posted Jul 17, 2019 03:14 PM
    Greetings!
    Because the 2540 only supports a single mirroring session, the syntax is a bit different:
    switch(config)# mirror-port 24
    The interface monitor command should work as expected.
