Wired Intelligent Edge
Port mirroring - stp blocked
  • 1.  Port mirroring - stp blocked
    Posted 15 days ago
    I'm actually monitoring some interfaces on our core switch and want to send these mirror traffic to another switch.
    The setup looks like below.
    Aruba core ( 3810) :
    interface Trk 1-10 > monitor all both mirror  1
    mirror 1 port 2/B2
    Aruba access switch (2540):
    interface 52 monitor
    mirror-port 18 > connect to IDS
    However STP blocks LAN connections, the setup looks like this.
    Core 1/ A1 & 2/A1 > Access  Switch (Port 49 & 50)  - Used for LAN connections
    Core 2/B2 > Access Switch Port 52 - Used for Port mirroring
    See logs:
    Core:
    I 06/17/24 11:32:04 00077 ports: ST2-CMDR: port 2/B2 is now off-line
    I 06/17/24 11:31:33 00076 ports: ST2-CMDR: port 2/B2 is now on-line
    I 06/17/24 11:31:32 00435 ports: ST2-CMDR: port 2/B2 is Blocked by STP
    Access:
    I 06/16/24 10:50:58 00076 ports: port 52 is now on-line
    I 06/16/24 10:50:58 00435 ports: port 50 is Blocked by STP
    I 06/16/24 10:50:58 00435 ports: port 49 is Blocked by STP
    As i can see it shutdown the ports used for LAN connections.
    Can someone shed some light.
