Port-Security configuration
  • 1.  Port-Security configuration
    Posted Aug 31, 2019 03:01 AM
    I am setting up port security.
    I want to be able to learn the MAC as devices are connected up to a predefined limit. If they change after being learned or something something is added I want the port to disable and get an SNMP notification.
    I know I cannot configure it on trunks because of the disable action. I believe I can configure it on ports that have things like hubs and mini switches, but I would need to use an alarm action, not the disable.
    Would I need to do something along the lines of this to have port security learn the MAC first like this:
    port-security (Interface) learn-mode limited-continuous address-limit 2 action send-disable
    After it has learned the MAC, how can I change it to static, but to keep the MAC it has learned? Or am I going to have to do the command with limited-continuous then take the MACs it learns and manually enter static and the mac-address (MAC)?
