port tag supported on AP60-93 ?
  • 1.  port tag supported on AP60-93 ?
    Posted Nov 22, 2012 11:20 AM
    Hello everyone,
    I'm new on the forum and i don't have lot of skill on aruba network, but you can help me to grow :)
    I have a question, but before a little point on my configuration.
    Currently I have two aruba controllers 3600 with a park of 130 AP, I have a mix of AP60 and AP93 in bridge mode with several SSID.
    My question, it's possible to plug an AP60 (in bridge mode) on a tag port in order to have two vlan on two SSID? How I can configure my AP?
    Thanks for your answer,
    Regards
    #3600
  • 2.  RE: port tag supported on AP60-93 ?
    Posted Nov 22, 2012 01:32 PM
    You can indeed do that.
    Assuming your VAPs are configured in bridge mode, with suitable VLANs assigned, then...
    To get you started, login to your controller and have a look at the "wired ap profiles" under the "AP" subtree. That will give you an idea of what settings you can apply.
    Create a wired ap profile, apply it to your ap/group and test!
  • 3.  RE: port tag supported on AP60-93 ?
    Posted Nov 22, 2012 01:36 PM
    That assumes of course, that you've already setup your switch ports (that attach to the APs) in the way you need!
  • 4.  RE: port tag supported on AP60-93 ?
    Posted Nov 23, 2012 11:40 AM
    Thank for your reply, I try it next week and I will do a feedback,
    Regards
  • 5.  RE: port tag supported on AP60-93 ?
    Posted Dec 06, 2012 10:15 AM
    Thank for the reply, it's solved,
    Regards
