Hi all
is it possible to auto kick devices that try to connect but dont end up getting an IP from the controller?
Yes, if you check the box "enforce DHCP" only those who get an IP via DHCP.
Furthermore, you can configure the controller to act as DHCP server. However, this is not recommended and should only be used for guest networks.
HTH
Kevin
