Possible bug? 'show auth-tracebuf' timestamps
  • 1.  Possible bug? 'show auth-tracebuf' timestamps
    Posted Jul 22, 2019 03:48 PM
    System time on my controller seems totally synced to global time, and when I look at that time in various places like Show Version and in WebUI Infrastructure it shows an accurate time.
    However when I do a 'show auth-tracebuf' command, it seems like all the entries are timestamps with a time that is 1 minute previous to the system time at which they occurred.
    Can someone confirm this seems like a bug and not a user confusion issue?  Currently on version 8.5.0.0.
    (Controller333) *[mynode] #show auth-tracebuf
    Auth Trace Buffer
    Jul 22 13:40:10  wpa2-key4             ->  ^^:^^:^^:28:0b:25  f4:2e:7f:^^:^^:^^        -    95
    Jul 22 13:40:10  station-up             *  ^^:^^:^^:28:02:3f  f4:2e:7f:^^:^^:^^        -    -    wpa2 psk aes
    Jul 22 13:40:10  wpa2-key1             <-  ^^:^^:^^:28:02:3f  f4:2e:7f:^^:^^:^^        -    117
    Jul 22 13:40:10  wpa2-key2             ->  ^^:^^:^^:28:02:3f  f4:2e:7f:^^:^^:^^        -    117
    Jul 22 13:40:10  wpa2-key3             <-  ^^:^^:^^:28:02:3f  f4:2e:7f:^^:^^:^^        -    151
    Jul 22 13:40:10  wpa2-key4             ->  ^^:^^:^^:28:02:3f  f4:2e:7f:^^:^^:^^        -    95
    Jul 22 13:40:11  station-down           *  ^^:^^:^^:28:09:6f  f4:2e:7f:^^:^^:^^        -    -
    Jul 22 13:40:11  station-up             *  ^^:^^:^^:28:0a:fc  f4:2e:7f:^^:^^:^^        -    -    wpa2 psk aes
    Jul 22 13:40:11  wpa2-key1             <-  ^^:^^:^^:28:0a:fc  f4:2e:7f:^^:^^:^^        -    117
    Jul 22 13:40:11  wpa2-key2             ->  ^^:^^:^^:28:0a:fc  f4:2e:7f:^^:^^:^^        -    117
    Jul 22 13:40:11  wpa2-key3             <-  ^^:^^:^^:28:0a:fc  f4:2e:7f:^^:^^:^^        -    151
    Jul 22 13:40:11  wpa2-key4             ->  ^^:^^:^^:28:0a:fc  f4:2e:7f:^^:^^:^^        -    95
    Jul 22 13:40:13  station-down           *  ^^:^^:^^:28:0a:37  f4:2e:7f:^^:^^:^^        -    -
    (Controller333) *[mynode] #  show clock
    Mon Jul 22 13:41:23 CST 2019
    (Controller333) *[mynode] #show ntp status
    Authentication:         disabled
    time since restart:     117467
    time since reset:       117467
    packets received:       184
    packets processed:      180
    current version:        180
    previous version:       0
    declined:               0
    access denied:          0
    bad length or format:   0
    bad authentication:     0
    rate exceeded:          0
    system peer:          ns1.baxterit.net
    system peer mode:     client
    leap indicator:       00
    stratum:              3
    precision:            -18
    root distance:        0.05148 s
    root dispersion:      0.03819 s
    reference ID:         [54.39.13.155]
    reference time:       e0e08c0c.fe2ee997  Mon, Jul 22 2019 13:25:00.992
    system flags:         auth monitor ntp kernel stats
    jitter:               0.000000 s
    stability:            0.062 ppm
    broadcastdelay:       -0.049988 s
    authdelay:            0.000000 s
    (Controller333) *[mynode] #show ntp servers
    NTP Server Table Entries
    Flags:     * Selected for synchronization
               + Included in the final selection set
               # Selected for synchronization but distance exceeds maximum
               - Discarded by the clustering algorithmn
               = mode is client
      remote                                  local                                    st   poll   reach    delay     offset      disp
    *ns1.baxterit.net                         10.x.y.z                                 2 1024     377    0.05080    -0.000368    0.13814
    Upstream NTP Server(s) are reachable.
    Time synchronization is with configured upstream NTP server.
    (Controller333) *[mynode] #show ver
    version                 Show System version
    (Controller333) *[mynode] #show version
    ArubaOS (MODEL: Aruba7024), Version 8.5.0.0
    Website: http://www.arubanetworks.com
    (c) Copyright 2019 Hewlett Packard Enterprise Development LP.
    Compiled on 2019-04-26 at 22:27:39 UTC (build 70258) by p4build
    ROM: System Bootstrap, Version CPBoot 1.0.0.0 (build 48228)
    Built: 2015-01-22 04:55:27
    Built by: p4build@re_client_48228
    Switch uptime is 9 days 2 hours 48 minutes 56 seconds
    Reboot Cause: User reboot (Intent:cause:register 78:86:0:2d)
    Supervisor Card
    Processor (XLP208 Rev B0 (Secure Boot) , 800 MHz) with 3797M bytes of memory.
    32K bytes of non-volatile configuration memory.
    3872M bytes of Supervisor Card system flash.
  • 2.  RE: Possible bug? 'show auth-tracebuf' timestamps
    Posted Jul 22, 2019 04:39 PM
    Auth-Tracebuf output is never live. It is something that happened in the past...(client authentication).
  • 3.  RE: Possible bug? 'show auth-tracebuf' timestamps
    Posted Jul 22, 2019 06:34 PM
    I did an experiment. I Forgot the wireless network on my phone. I re-entered the wireless network on my phone's config screen, with username trytryit (a username that had never been used before against this controller). On the controller CLI I typed in 'show clock', and I pressed enter on CLI and Accept on phone's wireless network config screen at the same time (within 1 second of each other).
    As you can see from CLI output of the show clock and show auth-tracebuf, events that happened at the same time in the controller are logged with two different times. The show auth-tracebuf timestamps are incorrect, even against the controller's own internal time. "16:29:22" on 'show clock' is the same actual time as "16:28:23" on show auth-tracebuf.
    (Controller333) *[mynode] #show clock
    Mon Jul 22 16:29:22 CST 2019
    (Controller333) *[mynode] #  show auth-tracebuf  | include  ^^:^^:^^:7b:36:6d
    Jul 22 16:28:23  station-up             *  ^^:^^:^^:7b:36:6d  f4:2e:7f:^^:^^:^^        -    -    wpa2 aes
    Jul 22 16:28:23  eap-id-req            <-  ^^:^^:^^:7b:36:6d  f4:2e:7f:^^:^^:^^        1    5
    Jul 22 16:28:23  eap-id-resp           ->  ^^:^^:^^:7b:36:6d  f4:2e:7f:^^:^^:^^        1    13   trytryit
    Jul 22 16:28:23  rad-req               ->  ^^:^^:^^:7b:36:6d  f4:2e:7f:^^:^^:^^        112  202  10.6.20.2
    Jul 22 16:28:23  rad-reject            <-  ^^:^^:^^:7b:36:6d  f4:2e:7f:^^:^^:^^/NPS-1  112  44
    Jul 22 16:28:23  eap-failure           <-  ^^:^^:^^:7b:36:6d  f4:2e:7f:^^:^^:^^        1    4    server rejected
    Jul 22 16:28:23  station-down           *  ^^:^^:^^:7b:36:6d  f4:2e:7f:^^:^^:^^        -    -
    Jul 22 16:28:24  station-up             *  ^^:^^:^^:7b:36:6d  f4:2e:7f:^^:^^:^^        -    -    wpa2 aes
    Jul 22 16:28:24  eap-id-req            <-  ^^:^^:^^:7b:36:6d  f4:2e:7f:^^:^^:^^        1    5
    Jul 22 16:28:24  eap-id-resp           ->  ^^:^^:^^:7b:36:6d  f4:2e:7f:^^:^^:^^        1    13   trytryit
    Jul 22 16:28:24  rad-req               ->  ^^:^^:^^:7b:36:6d  f4:2e:7f:^^:^^:^^        113  202  10.6.20.2
    Jul 22 16:28:24  station-down           *  ^^:^^:^^:7b:36:6d  f4:2e:7f:^^:^^:^^        -    -
    Jul 22 16:28:24  rad-reject            <-  ^^:^^:^^:7b:36:6d  f4:2e:7f:^^:^^:^^/NPS-1  113  44
    Jul 22 16:28:24  eap-failure           <-  ^^:^^:^^:7b:36:6d  f4:2e:7f:^^:^^:^^        1    4    server rejected
  • 4.  RE: Possible bug? 'show auth-tracebuf' timestamps
    Posted Jul 22, 2019 08:19 PM
    Please open a TAC case.  I don’t see that on my setup here.
  • 5.  RE: Possible bug? 'show auth-tracebuf' timestamps
    Posted Jul 23, 2019 10:16 AM
    Last night we upgraded to 8.5.0.1, and now when I do the same test the timestamp matches. So issue no longer present, and for that reason I won't open a case.
