Posturing iOS and Android
  • 1.  Posturing iOS and Android
    Posted Dec 24, 2015 10:00 AM
    I have a need to posture mobile devices like iOS and Andoid, specifically to determine if they have proper encryption enabled prior to allowing access to the wireless network. From what I know of CP it doesn't look there is support for iOS or android. Has anyone else found a way to do this with clearpass onguard or is this more of a function for MDM solutions?
    What about kicking off a nessus scan on initial connection to determine device compliance with the MDM encryption policies? Although this won't scan the device directly so only useful for those devices enrolled I would imagine.
    Appreciate any feedback from anyone who has run into this requirement on their network and how they satisfied it using clearpass, MDM, or some other solution.
    Thanks, GR
  • 2.  RE: Posturing iOS and Android
    Posted Dec 24, 2015 10:02 AM
    This is a function of MDM. ClearPass can then talk to your MDM solution.
    Sent from Nine
  • 3.  RE: Posturing iOS and Android
    Posted Dec 24, 2015 10:04 AM
    Got it, and from that info, clearpass can enforce a policy based on encryption level I am assuming.
    What about devices that are not part of any MDM solution or MDM is not available? Sounds like there is no way to determine encryption levels of a device directly from clearpass.
  • 4.  RE: Posturing iOS and Android
    Posted Dec 24, 2015 10:06 AM
    Correct. It is not possible to detect encryption out of band.
    Sent from Nine
