Power connect W-650 , does it support Aruba OS 8.0.7?
  • 1.  Power connect W-650 , does it support Aruba OS 8.0.7?
    Posted Mar 23, 2015 02:17 AM
    Hello Everyone,
    Good day!
    Due to
    W-Series AirWave Multiple Vulnerabilities (CVE-2015-1390, CVE-2015-1391, CVE-2015-2201, CVE-2015-2202)
    I am plannin go upgarde the Aruba OS for my W-650 from current Version 6.3.1.5 to new version 8.0.7.
    Will Power connect W-650 be able to support this  OS version?
    What are the key points to be considered for upgrading this to new version of Aruba OS.
  • 2.  RE: Power connect W-650 , does it support Aruba OS 8.0.7?
    Posted Mar 23, 2015 03:27 AM
    Hi!
    8.0.7 is a firmware for Airwave, your 650 is a controller and will need Aruba OS. You will need to look at the latest 6.3.1.15 or jump to 6.4. Beware that some APs won´t be able to do 6.4 so you´ll have to read the release notes thoroughly if you´re going to that version.
    Cheers,
  • 3.  RE: Power connect W-650 , does it support Aruba OS 8.0.7?
    Posted Mar 23, 2015 03:35 AM
    Thank you Christoffer .
    :) I had got confused.
    Thanks for your quick reply and explanation.
