Power Cut
  • 1.  Power Cut
    Posted Oct 23, 2017 09:26 AM
    One of the Clearpass Cluster nodes suffered a power cut this morning.
    It came back up and back in sync, but I have seen this error a few times afterwards:
    2017-10-23 14:19:55+01:00 CPPM[clp01] profiler: Profiler ip:192.168.70.8 unstable
    This is from both nodes - is this part of the resync or is it a problem?
  • 2.  RE: Power Cut
    MVP
    Posted Nov 09, 2017 03:05 PM
    I've experienced a similar issue after upgrades with an error that says "Battery Sync Unstable". Working with TAC they can stop/start this service or process and it should stabilize. I would start there.
  • 3.  RE: Power Cut
    Posted Nov 10, 2017 03:09 AM
    HI
    Thanks for the reply, yes it is back to normal now :)
  • 4.  RE: Power Cut
    Posted Oct 01, 2020 07:17 AM
    hello sir,
    which service that should i restart ?
    [appadmin@TBN-AT-AC01]# service status all
    Policy server [ cpass-policy-server ] is running
    TACACS server [ cpass-tacacs-server ] is running
    Radius server [ cpass-radius-server ] is running
    Async DB write service [ cpass-dbwrite-server ] is running
    DB replication service [ cpass-replication ] is running
    DB change notification server [ cpass-dbcn-server ] is running
    System monitor service [ cpass-sysmon-server ] is running
    System auxiliary service [ cpass-system-auxiliary-server ] is running
    Admin server [ cpass-admin-server ] is running
    Async netd service [ cpass-async-netd ] is running
    Multi-master cache [ cpass-multi-master-cache-server ] is running
    Domain Server [ cpass-domain-server@HO ] is running
    Stats collection service [ cpass-statsd-server ] is running
    Stats aggregation service [ cpass-carbon-server ] is running
    Ingress logger service [ cpass-igslogger-server ] is stopped
    Ingress logrepo service [ cpass-igslogrepo-server ] is stopped
    RadSec Service [ cpass-radsec ] is running
    AirGroup notification service [ airgroup-workqueue ] is running
    ClearPass Guest background service [ cpg-background ] is running
    ClearPass Guest cache [ cpg-redis-cache ] is running
    Extensions service [ cpass-extensions ] is running
    Micros Fidelio FIAS [ fias-server ] is running
    ClearPass Virtual IP service [ cpass-vip ] is running
    ClearPass IPsec service [ cpass-ipsec ] is running
  • 5.  RE: Power Cut
    MVP
    Posted Oct 01, 2020 08:22 AM
    I don't recall which service is tied directly to the battery sync or profiler, but if you need to restart them, just do a "service restart all" and allow CPPM to refresh all of the services.
    **NOTE - This will cause short outage with authentications and admin access to the server**
    Typically this process takes 30-60 seconds.
  • 6.  RE: Power Cut
    Posted Oct 02, 2020 07:44 AM
    hello sir,
    i believe i'm already restart all service, but those alert still occure, any other idea sir ?
  • 7.  RE: Power Cut
    MVP
    Posted Oct 02, 2020 08:02 AM
    I would suggest opening a case with TAC and have them investigate further.
    In previous experience, power loss to CPPM servers is not good. I've had
    servers become completely corrupted and had to RMA probably 3 or 4 over the
    years from power hits.
    TAC is your best next step. 1-800-WiFi-LAN or if you have an ASP account,
    you can generate a case online. Just remember to get your SN of CPPM for
    TAC - log into WebUI and click the version in the bottom right I believe it
    is, it should pop up a box with your SN.
  • 8.  RE: Power Cut
    Posted Oct 04, 2020 12:06 PM
    noted sir,
    tomorrow i will call TAC to investigate it
