last person joined: 7 hours ago
Power Injector Aruba IAP 103
  • 1.  Power Injector Aruba IAP 103
    Posted Jul 09, 2017 06:15 AM
    Hello. Tell please what compatible adapters can be used? What it is possible to replace with JW627A PD-3501G-AC 15.4W 802.3af PoE 10/100/1000Base-T Ethernet Midspan Injector.
    I can use these adapters, is written that they have a support 802.3 af
    1). PoE Intellinet 524179
    2). PoE TP-LINK TL-POE200
    P.S I tried to find this adapter in distributors but haven't found.
  • 2.  RE: Power Injector Aruba IAP 103
    Posted Jul 09, 2017 08:32 AM
    2). Doesn't approach. I have found another on the website PoE Injector Tp-Link TL-PoE150S, likely we will compatible
  • 3.  RE: Power Injector Aruba IAP 103
    Posted Jul 09, 2017 10:31 PM
    Any 802.3af certified power injector should work fine for the 103.
