Power supply faulty
  • 1.  Power supply faulty
    Posted Apr 12, 2013 05:10 AM
    I have a Aruba650 Controller  running an IOS version 5.0.3.3. Have been receiving heaps of alerts Indicating that the state of the power supply for this system is not NORMAL. I am unable to check the status of power supply from "Show Inventory" command.
    Is this a genuine fault or an issue with IOS.
    Can someone help me on this.?
    Logs:
    ArubaOS (MODEL: Aruba650), Version 5.0.3.3
    Website: http://www.arubanetworks.com
    Copyright (c) 2002-2011, Aruba Networks, Inc.
    Compiled on 2011-04-21 at 12:09:15 PDT (build 28008) by p4build
    ROM: System Bootstrap, Version CPBoot 1.0.0.0 (build 23274)
    Built: 2010-01-19 11:11:41
    Built by: p4build@re_client_23274
    Aruba650 Card Temperatures :
    : Card Temperature 31 C
    : CPU Temperature 53 C
    Aruba650 Fan Tachometers :
    : Chassis Fan A 6075 RPM
    : Chassis Fan B 5925 RPM
    : Chassis Fan C 5714 RPM
    Aruba650 Card Voltages :
    : CPU_V1 2500mV 2532 mV
    : CPU_V2 1800mV 1798 mV
    : CPU_V3 1000mV 990 mV
    : CPU_V4 900mV 918 mV
    : CPU_V5 5000mV 4998 mV
    : CPU_V6 3300mV 3300 mV
    : MAIN_V1 5000mV 5004 mV
    : MAIN_V2 3300mV 3306 mV
    : MAIN_V3 1900mV 1906 mV
    : MAIN_V4 1500mV 1514 mV
    : MAIN_V5 1200mV 1194 mV
    : MAIN_V6 2500mV 2526 mV
    Vijay
  • 2.  RE: Power supply faulty
    Posted Apr 12, 2013 05:49 AM
    Please open a support case so they can take a look.
  • 3.  RE: Power supply faulty
    Posted Apr 12, 2013 05:58 AM
    Hi Joseph,
    Thanks for your reply. Will open a case
    But is there any other command where i can check the status of power supply ?
  • 4.  RE: Power supply faulty
    Posted Apr 12, 2013 05:59 AM
    You are running the command to check it.
    What alerts are you getting?
  • 5.  RE: Power supply faulty
    Posted Apr 12, 2013 08:00 AM
    Device is located at Client's place. I dont have the visibilty to the device.
    Event summary:
    "Indicates that the state of the power supply for this system is not NORMAL"
  • 6.  RE: Power supply faulty
    Posted Apr 12, 2013 08:02 AM
    What monitoring software is sending this information?
    From the show inventory, the device voltage seems ok.
  • 7.  RE: Power supply faulty
    Posted Apr 18, 2013 02:58 PM
    SMARTS.. so can this alert be ignored ?
