Power Supply S/N via CLI
  • 1.  Power Supply S/N via CLI
    Posted Jan 25, 2016 05:43 PM
    Hi Aruba team,
    Do you know how can i obtain the serial number of the power supplies via CLI Controller?
    Thanks in advance.
    Best regards,
    Alberto.
  • 2.  RE: Power Supply S/N via CLI
    Posted Jan 25, 2016 06:15 PM
    For which device, specifically?
  • 3.  RE: Power Supply S/N via CLI
    Posted Jan 25, 2016 06:29 PM
    For the controller 6000 please.
  • 4.  RE: Power Supply S/N via CLI
    Posted Jan 26, 2016 09:35 AM
    Hi Alberto,
    Please run the following command:
    Aruba# show inventory
  • 5.  RE: Power Supply S/N via CLI
    Posted Jan 26, 2016 05:34 PM
    Hi Nitesh,
    When i run show inventory command i can't see the SN of the power supplies. This is the output of this command:
    Supervisor Card slot : 0
    Mobility Processor : FPGA Rev 0x13021320
    Mobility Processor Assembly# : 2010****
    Mobility Processor Serial# : F0095****
    SC Assembly# : 2010**** (Rev:08.02)
    SC Serial# : F0093**** (Date:09/25/08)
    SC Model# : Aruba6000
    Mgmt Port HW MAC Addr : 00:0B:86:61:**:**
    HW MAC Addr : 00:0B:86:0B:85:** to 00:0B:86:0B:85:**
    XPLD Version : (Rev: 20)
    PEER Supervisor Card : Absent
    Line Card 0 : Not accessible from this SC
    Line Card 1 : Absent
    Line Card 2 : Present
    Line Card 2 FPGA : LCCI Rev 0x6
    Line Card 2 Switch Chip : Broadcom 56308 Rev 0xA
    Line Card 2 Mez Card : Present
    Line Card 2 SPOE : Present
    Line Card 2 Sup Card 0 : Present ( Active )
    Line Card 2 Sup Card 1 : Absent
    Line Card 2 Assembly# : 2010**** (Rev:02.00) (24FE+2GE)
    Line Card 2 Serial# : F0049**** (Date:09/09/07)
    Line Card 2 SPOE Assembly# : 2010**** (Rev:01.00) (SPOE-1)
    Line Card 2 SPOE Serial# : F0050****
    Line Card 2 MEZZ Assembly# : 2010**** (Rev:01.00)
    Line Card 2 MEZZ Serial# : F0049****
    Line Card 3 : Absent
    FAN 0 : OK, Speed High
    FAN 1 : OK, Speed High
    FAN 2 : OK, Speed High
    Fan Tray Assembly# : 2010**** (Rev:01.00)
    Fan Tray Serial# : F0216**** (Date:02/08/12)
    Back Plane Assembly# : 2010**** (Rev:02.06)
    Back Plane Serial# : A0000**** (Date:09/18/08)
    Power Supply type : Power One (400W)
    Power Supply 0 : OK (400W)
    Power Supply 1 : OK (400W)
    Power Supply 2 : OK (400W)
    M3mk1 Card Temperatures : M3mk1 card 42 C
    : CPU 59 C
    AMP Card Temperatures : Processor Card 37 C
    : Mobility Processor 53 C
    : M3mk1 CPU Fan Speed 7500 RPMs
    M3mk1 Card Voltages : M3mk1 5000mV 4950 mV
    : M3mk1 3300mV 3340 mV
    : M3mk1 2500mV 2482 mV
    : M3mk1 1800mV 1790 mV
    : M3mk1 1500mV 1500 mV
    : M3mk1 1250mV 1250 mV
    : M3mk1 1200mV 1210 mV
    : M3mk1 IBC 12000mV 11560 mV
    : M3mk1 CPU CORE 1200mV 1210 mV
    : M3mk1 XGMII VTT 750mV 750 mV
    : M3mk1 VTT0(a&b) 900mV 900 mV
    : M3mk1 VTT1(c&d) 900mV 900 mV
    : AMP 3300mV 3300 mV
    : AMP 2500mV 2480 mV
    : AMP 1800mV 1800 mV
    : AMP 1500mV 1500 mV
    : AMP BCM 1200mV 1180 mV
    : AMP FPGA 1200mV(1) 1200 mV
    : AMP FPGA 1200mV(2) 1200 mV
    Can you help me to find the serial numbers?
    Thanks in advance.
  • 6.  RE: Power Supply S/N via CLI
    Posted Jan 27, 2016 10:47 AM
    Hi Alberto,
    If you don't mind, please let me know the reason/use-case for getting the serial number of power supply
    on 6000 controller.
    We normally use the backplane serial number in case any replacements of the power supplies are needed.
  • 7.  RE: Power Supply S/N via CLI
    Posted Jan 27, 2016 12:10 PM
    Hi again,
    I need those serial numbers because Aruba request them to renew maintenance. I need the serial number of each power supply of each controller (3 supplies per Controller),  to allow full maintenance for 2 controllers.
    I can not restart the controller or disconnect, so I require some other method besides the disassembly the controller.
    Thanks in advance.
  • 8.  RE: Power Supply S/N via CLI
    Posted Jan 27, 2016 02:08 PM
    Hi Alberto,
    Thank you for the info.
    I am not aware of any other command to get the serial numbers for the power supplies.
    if possible, try to check with the renewals team if the backplane serial number will work.
    The output for show inventory has the backplane serial no .
