powersave DOS attack message
  • 1.  powersave DOS attack message
    Posted Apr 25, 2014 06:35 AM
    I am seeing the lot of power save dos attack messages on the controller. In the ids-dos profile power save dos attack is enabled.
    Could anyone let me know how to avoid these messages on the controller without disabling the power save dos attack in ids profile?
    Can we ignore this message? please be informed that there is no impact seen on the network.
    Thanks.
  • 2.  RE: powersave DOS attack message
    Posted May 02, 2014 12:46 AM
    It depends on the version of code you are running.  There was a bug fixed in 6.1.3.2 where we misinterpreted certain frames as a powersave DOS attack.
  • 3.  RE: powersave DOS attack message
    Posted May 07, 2014 07:45 PM
    Would this affect version 6.1.2.7?
  • 4.  RE: powersave DOS attack message
    Posted May 07, 2014 07:46 PM
    yes
  • 5.  RE: powersave DOS attack message
    Posted May 16, 2014 11:19 PM
    Thanks CJ,
    Could you please let me know the correct recommended values In ids profile for the power save does attack?
  • 6.  RE: powersave DOS attack message
    Posted May 17, 2014 07:26 AM
    The defaults should be fine.
