last person joined: 10 hours ago
PPPoE connection error on controller 650
  • 1.  PPPoE connection error on controller 650
    Posted Aug 13, 2015 11:12 PM
    We have aruba 650 controller and use with PPPoE configure,
    it can work before.
    Last week we found the PPPoE is not work.
    It will connect and disconnect around 7min.
    Did anyone have an idea on it?
    Thank you very much
    Kenny chan
    Here is the error log.
    Aug 6 14:42:47 <pppd 203037> <ERRS> |pppoed| Invalid PPPoE tag length (17696)
    Aug 6 14:42:51 <pppd 203037> <ERRS> |pppoed| Invalid PPPoE tag length (17699)
    Aug 6 14:42:51 <pppd 203037> <ERRS> |pppoed| Invalid PPPoE tag length (17696)
    Aug 6 14:42:57 <pppd 203037> <ERRS> |pppoed| Invalid PPPoE tag length (17699)
    Aug 6 14:42:57 <pppd 203037> <ERRS> |pppoed| Invalid PPPoE tag length (17696)
    Aug 6 14:43:01 <pppd 203037> <ERRS> |pppoed| Invalid PPPoE tag length (1422)
    Aug 6 14:49:07 <pppd 203016> <ERRS> |pppoed| Max LCP ECHO failures reached. Exiting
    Aug 6 14:49:10 <fpapps 313215> <ERRS> |fpapps| PPPoE: pppoed process has died. Process ID: 4984
    Aug 6 14:49:44 <pppd 203037> <ERRS> |pppoed| Invalid PPPoE tag length (17696)
    Aug 6 14:50:08 <pppd 203037> <ERRS> |pppoed| Invalid PPPoE tag length (2489)
    Aug 6 14:50:10 <pppd 203037> <ERRS> |pppoed| Invalid PPPoE tag length (17696)
    Aug 6 14:50:38 <pppd 203037> <ERRS> |pppoed| Invalid PPPoE tag length (2490)
    Aug 6 14:50:50 <pppd 203037> <ERRS> |pppoed| Invalid PPPoE tag length (17696)
    Aug 6 14:51:08 <pppd 203037> <ERRS> |pppoed| Invalid PPPoE tag length (2491)
    Aug 6 14:51:11 <pppd 203037> <ERRS> |pppoed| Invalid PPPoE tag length (17696)
    Aug 6 14:51:39 <pppd 203037> <ERRS> |pppoed| Invalid PPPoE tag length (1468)
    Aug 6 14:51:59 <pppd 203042> <ERRS> |pppoed| PPPoE application error Timeout waiting for PADO packets
    Aug 6 14:52:01 <fpapps 313215> <ERRS> |fpapps| PPPoE: pppoed process has died. Process ID: 5588
    Aug 6 14:58:32 <pppd 203016> <ERRS> |pppoed| Max LCP ECHO failures reached. Exiting
    Aug 6 14:58:33 <fpapps 313215> <ERRS> |fpapps| PPPoE: pppoed process has died. Process ID: 5725
    Aug 6 14:59:04 <pppd 203037> <ERRS> |pppoed| Invalid PPPoE tag length (17696)
    Aug 6 14:59:33 <pppd 203037> <ERRS> |pppoed| Invalid PPPoE tag length (2541)
    Aug 6 14:59:38 <pppd 203037> <ERRS> |pppoed| Invalid PPPoE tag length (17696)
    Aug 6 15:00:03 <pppd 203037> <ERRS> |pppoed| Invalid PPPoE tag length (2542)
    Aug 6 15:00:04 <pppd 203037> <ERRS> |pppoed| Invalid PPPoE tag length (17696)
    Aug 6 15:00:33 <pppd 203037> <ERRS> |pppoed| Invalid PPPoE tag length (2543)
    Aug 6 15:00:34 <pppd 203037> <ERRS> |pppoed| Invalid PPPoE tag length (17696)
    Aug 6 15:01:03 <pppd 203037> <ERRS> |pppoed| Invalid PPPoE tag length (1520)
    Aug 6 15:01:24 <pppd 203042> <ERRS> |pppoed| PPPoE application error Timeout waiting for PADO packets
    Aug 6 15:01:24 <fpapps 313215> <ERRS> |fpapps| PPPoE: pppoed process has died. Process ID: 6228
    Aug 6 15:08:01 <pppd 203016> <ERRS> |pppoed| Max LCP ECHO failures reached. Exiting
    Aug 6 15:08:02 <fpapps 313215> <ERRS> |fpapps| PPPoE: pppoed process has died. Process ID: 6541
    Aug 6 15:08:32 <pppd 203037> <ERRS> |pppoed| Invalid PPPoE tag length (17696)
    Aug 6 15:08:56 <pppd 203037> <ERRS> |pppoed| Invalid PPPoE tag length (2493)
    Aug 6 15:08:56 <pppd 203037> <ERRS> |pppoed| Invalid PPPoE tag length (17696)
  • 2.  RE: PPPoE connection error on controller 650
    Posted Aug 14, 2015 07:37 PM
    What version of ArubaOS is this?
  • 3.  RE: PPPoE connection error on controller 650
    Posted Aug 14, 2015 09:04 PM
    ArubaOS (MODEL: Aruba650), Version 6.4.0.3
    Thank you!
    Best regards
    Kenny Chan
  • 4.  RE: PPPoE connection error on controller 650
    Posted Aug 16, 2015 11:50 PM
    hi Kenny
    In general, the first thing is that 6.4.0.x is way too old - please upgrade to something like 6.4.2.10). The logs you pasted suggest something connectivity related
    and
    The other errors about tag len are implying there is something being sent the pppoe daemon on the controller doesnt like - but i see those messages in other logs, it may be normal.
    Can you make a packet capture of the pppoe uplink port using a port mirror + wireshark - capture for about 10 minutes - that should give us a better idea of the problem.
    regards
    -jeff
  • 5.  RE: PPPoE connection error on controller 650
    Posted Sep 04, 2015 12:00 PM
    Currently we are having a similar issue with several controllers (mostly 7005 running 6.4.3.1), but have seen this off and on throughout the years with 620 and 650 controllers running various flavours of 6.1 as well.
    In our case, we see PPPoE disconnect every 3-4 minutes, and then re-connect.  I have seen the same Max LCP echo requests message in our logs as well, although usually we get a LCP TERMREQ error instead.
    I have done a packet capture of the uplink, and in our case, what we are seeing is a failure to reply to PPP LCP echo requests sent by the ISP, and the failure of the controller to respond to these causing the ISP to close the connection.
    I just thought I would mention it, as we are currently working with Aruba TAC to try and find a solution to our issue, so if anything comes out of it, I will try and remember to post the results in case it might help your situatiion as well :)
  • 6.  RE: PPPoE connection error on controller 650
    Posted Jun 08, 2016 03:32 AM
    Hello eightender did you manage to deal with this problem with TAC help.
    Facing the same problem on Aruba 620 controller on 6.4.2.4, 6.4.2.16, 6.4.2.17 and 6.4.3.9 too!
    Every 5-7 minutes faces with PPPoE connection problem.
    So now looking for someone who may help me with :(
    Will be gratefull for any help!
