PPPoE Modem functionality
  • 1.  PPPoE Modem functionality
    Posted Mar 08, 2016 02:59 AM
    Is it possible to use PPPoE without a dedicated Modem with the Aruba Instants or the Branch Controller series?
  • 2.  RE: PPPoE Modem functionality
    Posted Mar 08, 2016 06:17 AM
    The short answer is yes:
    http://www.arubanetworks.com/techdocs/Instant_42_WebHelp/InstantWebHelp.htm?_ga=1.43038629.1615771646.1440445030#search-pppoe
    http://www.arubanetworks.com/techdocs/ArubaOS_6.4.4.x_WebHelp/Web_Help_Index.htm#search-pppoe
    The real answer is that you should get a single device that you are interested it, and test it with your carrier, if possible.
  • 3.  RE: PPPoE Modem functionality
    Posted Mar 08, 2016 06:20 AM
  • 4.  RE: PPPoE Modem functionality
    Posted Mar 30, 2016 04:52 AM
    I had a longer discussion with some guys from the local product management.
    In fact, without Modem it wont be possible to use the Instants.
