Pre Auth check with Self-Reg login page in Clearpass Guest?
  • 1.  Pre Auth check with Self-Reg login page in Clearpass Guest?
    Posted Apr 21, 2017 12:38 PM
    Hi:
    I've setup a guest network with a self-reg portal in Clearpass Guest, and it's working fine.
    But is there a way to do a Pre-Auth check with the login form?
    I can modify a few parameters of the login page from the self-reg Advanced Editor, but Pre-Auth check is not an option.
    I can't seem to find anywhere else to edit the login form. It's not listed under "Pages -- Web Logins."
    Thanks.
  • 2.  RE: Pre Auth check with Self-Reg login page in Clearpass Guest?
    Posted Apr 22, 2017 06:26 AM
    We have pre-auth option in Guest/Weblogin page
    Home » Configuration » Pages » Guest Self-Registrations> Advance Setting> Login form
     In Weblogin page
    Home » Configuration » Pages » Web Logins>Login form > * Pre-Auth Check:
    Select how the username and password should be checked before proceeding to the NAS authentication.
    Pavan
