pre-authentication function
  • 1.  pre-authentication function
    Posted May 28, 2013 03:33 PM
    Hi all
    I want to know whether Aruba 6.1release support pre-authentication function or not?
    If I take WiFi packet capture then in beacon frame I can see it is displaying as transmitter will not support pre authentication.if it supports then what authentication or encryption method should I use so that I can use pre authentication in 6.1 version?
    Thanks in advance
  • 2.  RE: pre-authentication function
    Posted May 28, 2013 03:37 PM
    What is pre-authentication?
  • 3.  RE: pre-authentication function
    Posted May 29, 2013 04:09 AM
    When we see in beacon frame under RSN capabilities it is showing transmitter will not support pre authentication.
    Pre authentication is user can authenticate to other APs prior to the roaming through the currently associated AP.
    Please correct me if I am wrong.
  • 4.  RE: pre-authentication function
    Posted May 29, 2013 08:08 AM
    What is the use case for pre-authentication?  How important is it?
  • 5.  RE: pre-authentication function
    Posted May 30, 2013 08:32 AM
    No , currently we dont support this.
    This functionality use to be supported in earlier AOS releases 3.x, but not now.
