Pre-defined Firewall Policies not having pre-defined ACLs on 6.3.0.1
  • 1.  Pre-defined Firewall Policies not having pre-defined ACLs on 6.3.0.1
    Posted Aug 10, 2013 05:28 AM
    Hello All,
    I noticed that on AOS 6.3.0.1 that the pre-defined Firewall Policies such as logon-control, captive portal no longer have their pre-defined ACLs associated with them.
    Is this something new? Is this a bug on the Code? What's up with Aruba on this? Or I'm I the only one having this issue?
    Any feedback will be highly appreciated.
  • 2.  RE: Pre-defined Firewall Policies not having pre-defined ACLs on 6.3.0.1
    Posted Aug 10, 2013 05:39 AM
    I see those there , make sure you have the PEF license
  • 3.  RE: Pre-defined Firewall Policies not having pre-defined ACLs on 6.3.0.1
    Posted Aug 10, 2013 05:47 AM
    I definitely have the PEF License.
    AP Licenses 1024
    RF Protect Licenses 1024
    PEF Licenses 1024
    Overall AP License Limit 1024
    So you see your pre-defined ACLs associated with these Firewall Policies?
  • 4.  RE: Pre-defined Firewall Policies not having pre-defined ACLs on 6.3.0.1
    Posted Aug 10, 2013 05:50 AM
    So under "Policies", how many rule counts do you have associated with captiveportal or logon-control?
  • 5.  RE: Pre-defined Firewall Policies not having pre-defined ACLs on 6.3.0.1
    Posted Aug 10, 2013 06:06 AM
    I have attached some screenshots
  • 6.  RE: Pre-defined Firewall Policies not having pre-defined ACLs on 6.3.0.1
    Posted Aug 10, 2013 06:08 AM
    wow!!! I need to open a Ticket with TAC then.
  • 7.  RE: Pre-defined Firewall Policies not having pre-defined ACLs on 6.3.0.1
    Posted Aug 10, 2013 06:15 AM
    You should .
    Try a couple of things :
    - try reloading the code into the other partition , you in case there something that got corrupted when you first loaded
    - do you see this in the GUI and CLI ?
    - do a show log system and if there's any errors that might be related to this.
  • 8.  RE: Pre-defined Firewall Policies not having pre-defined ACLs on 6.3.0.1
    Posted Aug 10, 2013 06:24 AM
    No pre-defined ACL for the Policies on both GUI and CLI.
    Nothing on the "show log system" referencing this issue.
    Are you recommending I upgrade the other Partition? Do you think I should re-apply the License after the upgrade.
    I don't re-applying the License will make any difference. What do you think?
  • 9.  RE: Pre-defined Firewall Policies not having pre-defined ACLs on 6.3.0.1
    Posted Aug 10, 2013 07:26 AM
    Well, if only I remembered to reboot my Controller after applying the License.
    Maybe I wouldn't have been awake so early trying to figure out why my pre-defined ACLs weren't coming up!!
