Pre-populate Endpoint database with Subnet / Endpoint Scan
  • 1.  Pre-populate Endpoint database with Subnet / Endpoint Scan
    Posted Feb 17, 2015 10:04 PM
    Is it possible to combine the actions of the subnet scan and the NMAP plugin to pre-populate the endpoint database without using an Alert on a service policy.
    It would be great for pre-scanning a network so that you know what device types to include in your role mapping / enforcement profiles.
  • 2.  RE: Pre-populate Endpoint database with Subnet / Endpoint Scan
    Posted Feb 17, 2015 10:57 PM
    Also can you force start a subnet scan?
  • 3.  RE: Pre-populate Endpoint database with Subnet / Endpoint Scan
    Posted Feb 18, 2015 12:01 AM
    Hey Scott,
    This and a lot of other things will be in 6.5.... you should have your hands on the code in the next few days :-)
    Does this help you?
  • 4.  RE: Pre-populate Endpoint database with Subnet / Endpoint Scan
    Posted Feb 18, 2015 06:53 PM
    Hi Danny,
    Thats great news!
    Looking forward to 6.5 even more now!
    Scott
  • 5.  RE: Pre-populate Endpoint database with Subnet / Endpoint Scan
    Posted Feb 18, 2015 06:56 PM
    One more question, in 6.4, is there any way to validate a scan has taken place? I've set one up and i know there are devices on the subnet i'm scanning but i've returned no results in the endpoint database.
  • 6.  RE: Pre-populate Endpoint database with Subnet / Endpoint Scan
    Posted Feb 18, 2015 09:46 PM
    Scott,
    The scan in 6.4 is a snmp scan and the interval is on the cluster-wide settings [default-24-hours, minimum of 6-hours].... we should post a message ot the event-log when this runs from memory....
    In 6.5 we are adding a lot more scanning options.... again hope some of this helps.....
    We can add multiple snmp community-strings to check, previously it was only public.... now we can add as many as required and specific their type V2,V2c,V3 etc.
    We will also
  • 7.  RE: Pre-populate Endpoint database with Subnet / Endpoint Scan
    Posted Feb 19, 2015 12:43 AM
    Thanks Danny!
