Pre-shared key lease period
  • 1.  Pre-shared key lease period
    Posted Jan 02, 2015 01:19 AM
    We hv 7200 controller & CPPM setup
    i am going to configure GUEST ssid with pre-shared key base auth. access for guest users.
    Is it possible to create multiple pre-shared key with respective lease period?
    The first pre-shared key will expire in 1 month and so on...
    Nik..
  • 2.  RE: Pre-shared key lease period
    Posted Jan 02, 2015 07:00 AM
    No.  You have to change it manually.  If you have Airwave, you can schedule changes to a controller's configuration.
  • 3.  RE: Pre-shared key lease period
    Posted Jan 02, 2015 09:43 AM
    Airwave POC is going on.
    Where i can configure schedule changes for controller in Airwave?
  • 4.  RE: Pre-shared key lease period
    Posted Jan 02, 2015 10:15 AM
    Using scheduled configuration requires you to use Airwave to manage the configuration of the controller completely through airwave, which means the controller would need to be in manage mode in Airwave.  If you do not already do this, it takes some time to understand fully, so I would not do it during a POC.  It is certainly an advanced topic.  The Airwave controller configuration guide is here:  http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=14107
    The portion you want is "Scheduling Configuration Changes".
