Predictive site survey client offset with Ekahau or Airmagnet
  • 1.  Predictive site survey client offset with Ekahau or Airmagnet
    Posted Mar 29, 2023 11:16 AM
    When doing site survey with sidekick you should use a client offset to match your "least capable, most important" device. But When doing predictive site survey you should not use the same client offset. Lower client offset should be used as you are not doing the offset against the sidekick antennas.
    Could please share your experience about this issue?
    I see some engineers using the same client offset for predictive site survey as the physical site survey.
    This is a good blog that explain the issue: https://todsfromds.com/2019/09/27/ekahau-masters-thoughts-about-offsets-in-ekahau-pro/
    Amor
    Luxembourg
