Prefer 5Ghz vs Force 5Ghz
  • 1.  Prefer 5Ghz vs Force 5Ghz
    Posted Jan 28, 2015 03:38 AM
    What's different between Prefer 5Ghz and Force 5Ghz on band steering feature?
  • 2.  RE: Prefer 5Ghz vs Force 5Ghz
    Posted Jan 28, 2015 03:43 AM
    Bandsteering moves a device that supports 5ghz to the 5ghz band on a dual-band access point.  For some clients, this does not always work.  "Force" is more heavy-handed, but could create issues with clients.  If you are running ArubaOS 6.3 and above, ClientMatch is enabled by default and the "Band Steering" configuration is ignored.
  • 3.  RE: Prefer 5Ghz vs Force 5Ghz
    Posted Jan 28, 2015 03:46 AM
    Hi Start,
    you can see the difference in this definition in the ArubaOS UG:
    Massimo
    [If you found my post helpful, please give kudos]
  • 4.  RE: Prefer 5Ghz vs Force 5Ghz
    Posted Jan 28, 2015 04:28 AM
    Hi start.
    May this help you to find your answer.
  • 5.  RE: Prefer 5Ghz vs Force 5Ghz
    Posted Jan 28, 2015 04:29 AM
    Force 5Ghz, If client support only 2.4Ghz, They can't connect to AP right ?
  • 6.  RE: Prefer 5Ghz vs Force 5Ghz
    Posted Jan 28, 2015 04:30 AM
    If a client does not support 5ghz, it will not be steered, period.
  • 7.  RE: Prefer 5Ghz vs Force 5Ghz
    Posted Jan 28, 2015 04:32 AM
    Yeah, AP will not respond with there req.
