last person joined: 11 hours ago
Preferred Band & Band Steering
  • 1.  Preferred Band & Band Steering
    Posted Sep 23, 2016 01:04 AM
    Would someone do the honors of explaining the different behavior between the following for the IAPs?
    Under System, there is an option for "Preferred Band".
    Under RF, there is an option for "Band Steering".
    I would certainly love to push folks/devices to 5Ghz.  I'm just trying to better understand the differences between these two similar options and perhaps a best practice.  Any negative consequences to the 2.4Ghz radios if I set both above options to 5Ghz?
  • 2.  RE: Preferred Band & Band Steering
    Posted Sep 23, 2016 04:58 AM
    Two different things.
    Preferred Band is the band that the AP would be on if the AP only had a single radio.  Aruba no longer sells single radio APs, so that switch will not do anything.
    Band Steering stands by itself.  http://www.arubanetworks.com/techdocs/Instant_423_WebHelp/InstantWebHelp.htm#UG_files/ARM/Configuring_ARM-Features.htm
