Preload Image to AP-125 not working
  • 1.  Preload Image to AP-125 not working
    Posted May 30, 2016 08:21 AM
    we want to update from 6.4.2.3 to 6.4.4.6. To decrease downtime I wanted to preload images on all the APs. It is working fine for all APs except AP-125 models.
    As mentioned in EOL list AP-125 is supported within version 6.4.
    The errormessage is Flash image upgrade failed: Result code 255
    Any ideas how i can do the update. I'm unsure what will happen if i reload the controllers AP-125 might not come up when controller is on 6.4.4.6?
    Thanks in advance
  • 2.  RE: Preload Image to AP-125 not working
    Posted May 30, 2016 09:39 AM
    If the AP is working now, it should be fine when you reload the controller.  I am not sure if the AP-125 has enough memory to hold a new image for preload.  It should do a regular upgrade when the controller is reloaded.
  • 3.  RE: Preload Image to AP-125 not working
    Posted May 31, 2016 01:13 AM
    Thanks for the support.
    But i got it right that version 6.4.4.6 still supports AP-125?
  • 4.  RE: Preload Image to AP-125 not working
    Posted May 31, 2016 01:17 AM
  • 5.  RE: Preload Image to AP-125 not working
    Posted May 31, 2016 01:21 AM
    Thanks a lot!
  • 6.  RE: Preload Image to AP-125 not working
    Posted Sep 20, 2017 10:08 AM
    I've had this issue preloading 6.4.4.15 from 6.4.4.6.  Will the AP125's definitely upgrade on controller reboot?
    Eleanor
  • 7.  RE: Preload Image to AP-125 not working
    Posted Sep 21, 2017 01:04 AM
    In our environment updating ap-125 was successful. They rebootet after controller came up with new version.
  • 8.  RE: Preload Image to AP-125 not working
    Posted Sep 21, 2017 03:36 AM
    @emm502 wrote:
    Eleanor
    The AP-125s just like every other AP will always upgrade or downgrade to match the software version of the controller it connects to.
  • 9.  RE: Preload Image to AP-125 not working
    Posted Sep 21, 2017 03:44 AM
    I can confirm, the ap's upgraded on reboot.  I've never had a problem with preloading the ap125's before but I'm guessing they're getting low on memory with some of the more recent code.
  • 10.  RE: Preload Image to AP-125 not working
    Posted Sep 21, 2017 03:47 AM
    Preloading is optional and might save a little time, depending on the situation.  You should not have to preload to upgrade a controller.  Memory should not be a consideration in a normal upgrade.
