Preprovisioning a RAP 109 with a 3400 controller
  • 1.  Preprovisioning a RAP 109 with a 3400 controller
    Posted Oct 24, 2013 03:21 AM
    I am having an issue Preprovisioning a RAP 109 with a 3400 controller.  I have used the RAP Network guide and I am up to the stage of provisioning the RAP.  I have added the rap mac to rap whitelist however it does not connect to the controller.   When I look at the logs it states User BV0033925:24:de:c6:cd:65:6a was not found in the database. User BV0033925:24:de:c6:cd:65:6a Failed Authentication.
    How do I get the RAP to provision, do I have to add the user, I can't imagine that I would have to do this for each rap. Of course this is my first rap deployment.
    #3400
  • 2.  RE: Preprovisioning a RAP 109 with a 3400 controller
    Posted Oct 24, 2013 03:47 AM
    yes, you need to add it to the rap whitelist on the master controller.
    Configuration > AP Installation > Whitelist > Remote AP and then add the RAP into that.
    I assume you've already configured a nat pool for the RAPs?
  • 3.  RE: Preprovisioning a RAP 109 with a 3400 controller
    Posted Oct 24, 2013 08:07 PM
    I do have the rap in the whitelist with AP Group of Remote-AP-Group and have the ipsec address pool (called RAP), this is a subset of addresses 172.17.0.10- 20 on the same subnet as the controller 172.17.0.0/24 vlan 1
    Not sure if this is helpful but just to give a summary of what I have:
    Setup an Remote-AP-Group has a vap with vlan 17
    The Internal DB has a user rapuser with ap-role
    ap-role has vlan 1 with L2TP pool of RAP
    However when I connect the rap to the controller directly it picks up 172.17.0.51, however the rap does not provision.  Really not sure what I am missing here.
    Ideally what I want to do is have multiple rap's on different remote sites with different subnets for staff and again a different subnet for guests.
  • 4.  RE: Preprovisioning a RAP 109 with a 3400 controller
    Posted Oct 24, 2013 08:33 PM
    Make sure you are running the right minimum version of Code.
    The RAP 100 series access points requires ArubaOS 6.2.0.0 and above:  http://www.arubanetworks.com/pdf/products/DS_RAP-100.pdf
  • 5.  RE: Preprovisioning a RAP 109 with a 3400 controller
    Posted Oct 24, 2013 08:49 PM
    The rap is running 6.2.0.0-3.2.0.4_38110
  • 6.  RE: Preprovisioning a RAP 109 with a 3400 controller
    Posted Oct 24, 2013 08:50 PM
    The 3400 controller needs to be running 6.2.0.0 and above.
  • 7.  RE: Preprovisioning a RAP 109 with a 3400 controller
    Posted Oct 24, 2013 11:52 PM
    Ok I have updated the controller to 6.2 however the rap doesn't provision.  Any tips?
  • 8.  RE: Preprovisioning a RAP 109 with a 3400 controller
    Posted Oct 25, 2013 12:09 AM
    A RAP-109 is an InstantAP out of the box.  Have you gone into the IAP's Maintenance tab > Convert > then pointed the IAP to the controllers IP?  Once you do this the RAP-109 should set up a connection with the controller and get thin AP code and the config from the controller.
  • 9.  RE: Preprovisioning a RAP 109 with a 3400 controller
    Posted Oct 25, 2013 12:16 AM
    Unfortunately I got an error back trying this.
    Response data is corrupted!
    Request url part:
    opcode=convert-ap&host=172.17.0.254&oper_id=E4F01794-0E0E-491D-B8F5-45E6E325E8C8&mode=remote
  • 10.  RE: Preprovisioning a RAP 109 with a 3400 controller
    Posted Oct 25, 2013 06:04 AM
    Request url part:
    Is that when you try to do a convert from theGUI of the RAP109?
  • 11.  RE: Preprovisioning a RAP 109 with a 3400 controller
    Posted Oct 27, 2013 09:24 PM
    Correct and now I can't get into it.  I will try reset it.
  • 12.  RE: Preprovisioning a RAP 109 with a 3400 controller
    Posted Mar 07, 2014 11:00 AM
    Having the same with RAP-108. Did you fix this ? May I know how or what I can try more ?
    Thanks, regards
      Alex
  • 13.  RE: Preprovisioning a RAP 109 with a 3400 controller
    Posted Mar 09, 2014 05:47 PM
    Hi
    If you mean the data response corruption error,  there wasn't a fix besides resetting the device and trying again.  It did work on the third attempt.
    For connecting to the controller on the RAP interface this worked.  Maintenance tab > Convert > then pointed the IAP to the controllers IP?
    DL77
  • 14.  RE: Preprovisioning a RAP 109 with a 3400 controller
    Posted Mar 11, 2014 07:32 AM
    Yes I mean the data corruption error.
    I get it a lot of times and it always fails. Other RAP models go fine, so am not sure if it's the model or the specific unit.
    Why do you think it fails a few times and then works at the third time ? is there a reason ?
    Thanks, regards
      Alex
