Presence Analytics
  • 1.  Presence Analytics
    Posted Mar 21, 2017 08:37 PM
    I setup a 90 day trial for aruba central and i want to get presence analytics working. I have it enabled for signal strength and update speed but under the apps menu, all I see is network management. Any ideas?
  • 2.  RE: Presence Analytics
    Posted Mar 21, 2017 10:01 PM
    Under subscription assignment and move the slider from device management to service, then you need to select the select the AP and assign the services (guest , presence or clarity)
    Get Outlook for iOS
  • 3.  RE: Presence Analytics
    Posted Mar 21, 2017 10:11 PM
    Youre a champion!
