Prevent DHCP
  • 1.  Prevent DHCP
    Posted Feb 18, 2020 07:04 AM
    Dear Experts,
    In Instant, is there anyway to allow dhcp responses from authorized servers only? i tried to use inbound firewall rules but they dont seem to work. I have a legitimate server on my LAN that should service the dhcp requests for connecting client.
    Any ideas please?
  • 2.  RE: Prevent DHCP
    Posted Feb 18, 2020 07:37 AM
    I tried blocking icmp from all sources to all destinations. Still i am able to ping my lan machines from my wireless clients. In the explanation for inbound rules, its mentioned that if there is a deny rule, it will be applied
  • 3.  RE: Prevent DHCP
    MVP GURU
    Posted Feb 21, 2020 09:13 AM
    Have you tried configuring Centralized DHCP Scopes on the IAPs. Configuration > DHCP Server. You could set up an IP helper, and point DHCP to the servers you want responding. On the IAP you can also apply ACLs to the AP ports as well. See below example of me denying ICMP on the uplink port:
    wlan access-list session denyicmp
    rule 192.168.1.0 255.255.255.0 192.168.200.0 255.255.255.0 match icmp any any deny
    wired-port-profile denyicmp
    access-rule-name denyicmp
    enet0-port-profile denyicmp
  • 4.  RE: Prevent DHCP
    MVP GURU
    Posted Feb 21, 2020 09:30 AM
    Also I have tested with blocking icmp with this type of setup and it works. Just make sure your rules are in the right order so your DHCP is being denied unless form your DHCP server. Also make sure you apply and save:
    inbound-firewall
    rule 192.168.1.0 255.255.255.0 192.168.200.0 255.255.255.0 match 1 any any deny
    rule 192.168.1.0 255.255.255.0 192.168.200.0 255.255.255.0 match any any any permit
  • 5.  RE: Prevent DHCP
    Posted Feb 21, 2020 11:46 AM
    Dear Dustin,
    What does "1" implies here?
    rule 192.168.1.0 255.255.255.0 192.168.200.0 255.255.255.0 match "1" any
    any deny
  • 6.  RE: Prevent DHCP
    MVP GURU
    Posted Feb 21, 2020 02:40 PM
    When configuring the ACL in the GUI, it will insert the protocol number, but if you configure it in the CLI it will use the icmp name for the protocol identifier. See here for IANA Protocol Numbers: https://www.iana.org/assignments/protocol-numbers/protocol-numbers.xhtml
