prevent employees from accessing Guest SSID
  • 1.  prevent employees from accessing Guest SSID
    Posted May 29, 2017 04:50 PM
    I have 2 SSID
    • Guest SSID (To authenticate guest users logging in via captive portal)
    • Employee SSID (AD + MAC authentication )
    I need to prevent any employee from accessing the Guest SSID by using the MAC list (SHL) I used with the employee SSID
  • 2.  RE: prevent employees from accessing Guest SSID
    Posted May 29, 2017 09:33 PM
    You would have better luck by pushing the guest SSID via group policy to employee devices as a WEP SSID with a key, so that they cannot join the guest network.  Anything else requires more administrative work.
  • 3.  RE: prevent employees from accessing Guest SSID
    Posted May 30, 2017 04:48 AM
    Dear Cjoseph
    thanks for your reply .....but what about there mobiles ?
    Best Regards
  • 4.  RE: prevent employees from accessing Guest SSID
    Posted May 30, 2017 07:53 AM
    khaled,
    If there is a way that you can identify their mobiles via mac address, you can block them.  If not, you should make sure that employees do not have access to the approval mechanism or that the guest network has even less privileges than the production network.
