PRI-O sshd disconnecting: too many authentication failures for root
  • 1.  PRI-O sshd disconnecting: too many authentication failures for root
    Posted Apr 28, 2015 02:19 PM
    I have a S1500 switch that I am using for layer 3 roouting to my internet.
    My syslog server is choked with the info message:
    Is that attempts from the internet-side to ssh in? If so, how do I turn that option off? I have no desire to SSH into this switch from outside my WAN.
  • 2.  RE: PRI-O sshd disconnecting: too many authentication failures for root
    Posted Apr 28, 2015 02:21 PM
    You would need to add an ACL to your uplink port.
  • 3.  RE: PRI-O sshd disconnecting: too many authentication failures for root
    Posted Apr 28, 2015 05:08 PM
    The port that faces the internet is int 18.
    What command would I use to disallow SSH on this port? I just confirmed that I can enter an SSH session across the internet. I don't need to and I don't want to expose my switch to more risk than is necessary.
    It is currently connected:
    Metro Ethernet Ciena ---> aruba sw port 18 ---> aruba sw port 20 ---> Fortigate firewall
  • 4.  RE: PRI-O sshd disconnecting: too many authentication failures for root
    Posted Apr 28, 2015 03:25 PM
    Funny, the only reason I am seeing these errors is I am sending to a syslog server.
    If, on the switch's CLI, I perform a show log all | include "authentication" I get no results.
    Further, the syslog is saying the hostname of the message is 10.110.138.13; I have no device at this address and the switch is 10.110.138.138.
    Yet I see:
     4/28/2015 14:47 10.110.138.13 Info Apr 28 13:48:09 Aruba-S1500-Admin-WIFI.138:PRI-0 sshd[15974]: Disconnecting: Too many authentication failures for root
    coming (in waves of 40 or 50 at a time) from that .13 address.
    just after the latest wave of messages:
     4/28/2015 14:47 10.110.138.13 Info Apr 28 13:48:31 Aruba-S1500-Admin-WIFI.138:PRI-0 sshd[16102]: Received disconnect from 43.255.190.132: 11:
    and that IP address is definitely not in my network.
