Primary usage in IAP
  • 1.  Primary usage in IAP
    Posted Jul 19, 2018 12:09 PM
    Can we edit or configure more primary usage(Employee, Voice and Guest) in IAP
  • 2.  RE: Primary usage in IAP
    MVP EXPERT
    Posted Jul 19, 2018 12:30 PM
    No, they are predefined. What are you trying to achieve?
  • 3.  RE: Primary usage in IAP
    Posted Jul 19, 2018 02:30 PM
    Custemor asking to configure the BYOD using IAP, can i define one more primary usage as BYOD
  • 4.  RE: Primary usage in IAP
    Posted Jul 19, 2018 03:16 PM
    Most of the time you will be choosing the employee type, because it is the most flexible.  Voice will tag all of the packets as high priority regardless of what options you choose.  Choosing guest will give you Captive Portal Options.
    Those are the only difference, with Employee giving you the most flexibility.
