Print Template if else code to list guest user ssid per guest user role
  • 1.  Print Template if else code to list guest user ssid per guest user role
    Posted Sep 09, 2015 05:03 AM
    Hello community,
    can someone help me with a code for my print template?
    I want that the ssid name change with the user role. My code should be make:
    If Role Name = 4 then put text "WLAN = mobile",
    otherwise put text "WLAN = guest".
    I try this but didn´t work. I don´t know something about html code.
    {if $u.role_name} mobile
      <tr>
       <td class="nwaBody">Wlan = Mobile</td>
      </tr>
    <td class="nwaBody">Wlan = Guest</td>
     {/if}
  • 2.  RE: Print Template if else code to list guest user ssid per guest user role
    Posted Sep 11, 2015 08:39 AM
    I would think it should be something like this:
    {if $u.role_name}
      <tr>
       <td class="nwaBody">Wlan = {if $u.role_name=mobile}Mobile{else}Guest{/if}</td>
      </tr>
    {/if}
    First line triggers if there exists a $u.role_name
    Then third line enters Mobile as WLAN if the role equals mobile, or Guest if anything else.
    Please note:
    tr = table row
    td = table column/cell
  • 3.  RE: Print Template if else code to list guest user ssid per guest user role
    Posted Sep 14, 2015 04:53 AM
    Thanks a lot for the reply.
    There is a syntax error with "=" can you please help?
    {if $u.role_name}
      <tr>
      </tr>
    {/if}
    Error in template: [in __template__55f68ab234ee20.31538420.html line 3]: syntax error: unidentified token '=' (Smarty_Compiler.class.php, line 296)
  • 4.  RE: Print Template if else code to list guest user ssid per guest user role
    Posted Sep 14, 2015 03:21 PM
    Use double equals sign ==
    {if $u.role_name}
    Wlan = {if $u.role_name==mobile}Mobile{else}Guest{/if}
    {/if}
  • 5.  RE: Print Template if else code to list guest user ssid per guest user role
    Posted Sep 16, 2015 04:15 AM
    Thanks a lot for your help.
    Now I try to build all seetings we need in a print template.
    Thank you so much.
    Marco
