Printers with MAC-Auth disappears and lose connectivity
This thread has been viewed 43 times
  • 1.  Printers with MAC-Auth disappears and lose connectivity
    Posted Mar 27, 2023 03:54 AM
    Hi.
    I am using MAC authentication for Printers in my organization.
    My rule is: If the printer's MAC is known and another attribute I added manually to each printer: "Endpoint:Device-Type = Printer" exists, Then send some user-role (That is configured on the switch).
    Things are working fine but after a day, some of the printers "disappear" and only shutting down the port and bringing it back, makes them get back.
    Any ideas on how I can solve this issue?
    Best regards,
    Alon Haber
  • 2.  RE: Printers with MAC-Auth disappears and lose connectivity
    Posted Mar 27, 2023 04:09 AM
    Could you elaborate more on the 'disappear' ?
    Does it mean the printer lose connectivity, or only the logs in Access Tracker disappears ?
    Do u set any session timeout enforcement profile in the clearpass to send back into the switch/wlc ? Or maybe u hv default session timeout in the authenticator (sw/wlc) itself.
    But why disappear... I need to know first what u mean by disappear.
  • 3.  RE: Printers with MAC-Auth disappears and lose connectivity
    Posted Mar 27, 2023 05:49 AM
    Yes,
    It means printers lose connectivity.
    If I go into the switch, There is no MAC on the port. And under "Show port-access clients" there is no entry for the specific printer.
    If I shutdown the port and bring it back up, It would see the printer again.
    Best regards,
    Alon Haber
  • 4.  RE: Printers with MAC-Auth disappears and lose connectivity
    Posted Mar 27, 2023 04:21 AM
    Are the printers going into sleep mode? Have you tested with one printer to disable sleep mode and test the next day if it's still available?
  • 5.  RE: Printers with MAC-Auth disappears and lose connectivity
    Posted Mar 27, 2023 05:47 AM
    I didn't know there is an option to the printer to fo to sleep mode.
    But even if it does. The only way is to disable sleep mode ?
    Best regards,
    Alon Haber
  • 6.  RE: Printers with MAC-Auth disappears and lose connectivity
    Posted Mar 27, 2023 05:52 AM
    It's just to establish if that's the issue as opposed to something wrong with Clearpass or the Switch. I think it's a common issue.
  • 7.  RE: Printers with MAC-Auth disappears and lose connectivity
    Posted Mar 27, 2023 06:21 AM
    I will disable sleep mode on the printers and try again to authenticate.
    Thank you.
    Best regards,
    Alon Haber
  • 8.  RE: Printers with MAC-Auth disappears and lose connectivity
    Posted Mar 28, 2023 01:55 AM
    This link will describe best what you are experiencing.
    I have the same issue and for now I added to the switch port this command (ArubaOS) which seems to solve it.
    aaa port-access controlled-direction in
    although i still don't fully understand what downsides this command has.
  • 9.  RE: Printers with MAC-Auth disappears and lose connectivity
    Posted Apr 04, 2023 05:05 PM
    This is the answer. Have run into this a few times.
    "aaa port-access controlled-direction in" essentially means only apply policy / authenticate traffic coming "in" the port. If the printer goes to sleep, a packet destined for it can still be sent out the port to wake it up. Once it awakens you should see a new auth in your RADIUS server.
    ACNSA | ACEA | ACCP | ACMP
  • 10.  RE: Printers with MAC-Auth disappears and lose connectivity
    Posted Mar 28, 2023 03:25 AM
    Hi Alon,
    what type of Switches do you use?
    In case you use AOS (Procurve) you might want to check the logoff-period setting: i.e. aaa port-access authenticator 1 logoff-period 864000
    In case you use AOS CX (Aruba CX) you might want to check client inactivity timout in the local access role settings
    Kind regards
    Martin
    Martin
  • 11.  RE: Printers with MAC-Auth disappears and lose connectivity
    Posted 4 days ago
    Hi all,
    I ran into the same problem with a Lexmark printer (Lexmark Firmware, Magazine = LW50.PR2.P544-0, Kernel = FW5.CY.F544-0, Base = LW50.PR2.P544-0, Network = NH5.CY.N543-0, Network Driver = LW50.PR2.P544-0, Engine = FDN.PIR.E618-0).
    In the CX series switches no problem, in the procurve series switches, however, after about 10 minutes of inactivity the printer no longer responds.
    This is the configuration:
    aaa accounting update periodic 3
    aaa accounting network start-stop radius
    aaa authentication login privilege-mode
    aaa authentication ssh login radius local
    aaa authentication ssh enable radius local
    aaa authentication port-access eap-radius
    aaa port-access authenticator 1 client-limit 1
    aaa port-access authenticator active
    aaa port-access mac-based 1
    aaa port-access mac-based 1 logoff-period 99999
    Do you have any ideas?
    With the CX switches and the printer itself the problem does not arise.
    carabina5
  • 12.  RE: Printers with MAC-Auth disappears and lose connectivity
    Posted 3 days ago
    You may have a look at the mac-pinning feature in ArubaOS Switch (Provision/Procurve based).
