Hi guys,
Does anyone have a working template for printing many guest accounts (50+) over several pages of A4 paper without some of the receipts getting the tops or bottoms cut off? So say 10 to a page but only ten not ten and a bit from the next two in a 2 column spread for instance
Wes.
What template are you using? Each User HTML block is suppose to be wrapped in a tag telling printers not to break it. That being said, they have always been a bit trial and error when printing to Avery labels or the like.
The 2 column print template was the basis?
Wes
Whats the tag for each User HTML Block. I have the same issue, with 2 column list and customized template. When i print 6 Voucher on 1 a4 page. The Vouchers will get cut off
