Wired Intelligent Edge
Prioritize voice traffic on Aruba 2930
  • 1.  Prioritize voice traffic on Aruba 2930
    Posted May 26, 2020 06:40 AM
    Hi Guys,
    In fact I have a simple setup but i'm not too familiar with Aruba switches.
    My setup:
    I have 2 VLANS Voice & Data
    My configs:
    vlan 5
    name voice
    voice
    tagged 1
    vlan 10
    name data
    untagged 1
    How can I prioritize the voice traffic ?
    Thank
  • 2.  RE: Prioritize voice traffic on Aruba 2930
    Posted May 26, 2020 06:51 AM
    You can do with the below
    Syntax: vlan <vid> qos priority <0-7>
    Example:
    switch(config)# vlan 10 qos priority 4
    The qos priority default setting is 0 (normal), with 1 as the lowest priority and 7 as the highest priority.
    Please refer to Advanced Traffic Management Guide for ArubaOS-Switch : https://support.hpe.com/hpesc/public/docDisplay?docId=a00091305en_us for more detailed explanation.
    Hope it helps.
  • 3.  RE: Prioritize voice traffic on Aruba 2930
    Posted May 26, 2020 12:25 PM
    Using the voice command in the vlan already enables some qos and enables LLDP-MED.
    You can fine-tune it using manual commands, but in my experience, in a "normal" office environment, it is not needed.
    But then again I don't know your environment...
    You can read up more in this post:
    https://community.arubanetworks.com/t5/Wired-Intelligent-Edge-Campus/Voice-VLAN-on-Aruba-switches/td-p/417811
  • 4.  RE: Prioritize voice traffic on Aruba 2930
    MVP EXPERT
    Posted May 26, 2020 01:40 PM
    See also this topic:
    Use a voice vlan and use tagged vlans to your phones. The DHCP values pre-configured on your phones will be honored by the switch interface.
    Note that QOS need be set end-to-end, so from phone, on all interconnect switches, firewalls to the VOIP server. But for my understanding a voice vlan take care on that.
