problem adding new ap's
  • 1.  problem adding new ap's
    Posted Oct 05, 2020 07:43 AM
    i have an existing network with 105 ap's and 205 ap's
    the virtual controller sits on one of the 105's
    it's firmware is 6.4.4.8-4.2.4.9_61734
    i've added some new 303 ap's. they are connected to the network, and even if i try to do https web access to one of them, i'm immediatly redirected to the main ap, which is fine. but i can't see them in the ap list, none of the new ones. maybe a compatibility issue with old and new?
    thank you
  • 2.  RE: problem adding new ap's
    Posted Oct 05, 2020 07:51 AM
    I believe the lowest version of firmware on the 303 is
    The firmware version have to match before they can join the VC.
  • 3.  RE: problem adding new ap's
    Posted Oct 05, 2020 08:12 AM
    oh i see. where can i find the latest for 105 or 205 ap's?
  • 4.  RE: problem adding new ap's
    Posted Oct 05, 2020 08:24 AM
    You can search by the series name at the link below
    https://asp.arubanetworks.com/
  • 5.  RE: problem adding new ap's
    Posted Oct 06, 2020 11:42 AM
    yeah, the 105 firmware is quite old
    maybe i can move the management to one of the 205 and upgrade it further? will it help me "raise" the cluster's highest firmware?
  • 6.  RE: problem adding new ap's
    MVP EXPERT
    Posted Oct 06, 2020 11:49 AM
    The issue is that the AP303 requires a minimum firmware Aruba InstantOS 8.3.0.0. The IAP105 will only support up to Instant 4.2 and IAP205 in your network will not support anything higher then Instant 6.5.
    Aruba EoL
    AP303 Data Sheet
    You would need to either replace all of the 105/205 or have separate clusters where the IAP105/IAP205 do not mix with the AP303.
  • 7.  RE: problem adding new ap's
    Posted Oct 06, 2020 11:51 AM
    oh i see. so actually in an existing cluster of 105 and 205, there is no way for me to combine ap303? i have to setup a new separate cluster?
  • 8.  RE: problem adding new ap's
    MVP EXPERT
    Posted Oct 06, 2020 11:55 AM
    That is correct, due to the minimum firmware/maximum firmware supported of the IAP models.
  • 9.  RE: problem adding new ap's
    Posted Oct 06, 2020 12:01 PM
    thank you
    and what if the ap303 is the "leader" of the cluster? will it not change anything? the 105 and 205 is too low for him to manage?
  • 10.  RE: problem adding new ap's
    MVP EXPERT
    Posted Oct 06, 2020 12:02 PM
    It will not make a difference due to the firmware versions. In order for a IAP Cluster to be formed all IAPs must be on the same firmware version.
  • 11.  RE: problem adding new ap's
    Posted Oct 06, 2020 12:05 PM
    thank you very much for your information
