Network Management
problem after reeboting Airwave in VMWare
  • 1.  problem after reeboting Airwave in VMWare
    Posted Sep 09, 2012 06:45 PM
    Hi
    I have airwav runig on vm workstation ,  after instllation   once we reboot the AMP  for some reason  the GUI does not start , at the console we can see all the service is started ,
    same thing when  I tried install in vmclient same hapend to be , tried 7.2,- 7.3 - ,7.4
    So i hope I  am doing some thing wrong ,, the network config at VM is bridged
    Can anyone help
  • 2.  RE: problem after reeboting Airwave in VMWare
    Posted Sep 10, 2012 12:37 PM
    I've found that the services can take several minutes to start when running in a VM -- tech support has confirmed this, and pronounced it "normal" but "unexplained."
    --Matthew
  • 3.  RE: problem after reeboting Airwave in VMWare
    Posted Sep 12, 2012 01:55 PM
    Typically, after the install, AMP will take roughly 5-10 minutes to start up.  A way to check is to watch the processes using the following commands:
    # daemons
    --> this lists out the running daemons at the moment the command is given
    # wd
    (this is an alias for # watch daemons)
    --> this is same as above but refreshes every second
    Once this list is populated to about 15 daemons, the AMP UI should be available.  If it's taking longer than 5-10 minutes, it could mean that you're hitting a potential performance issue (if that's the case, check "# top -c", make sure swap isn't being hit).
