Problem AP225
  • 1.  Problem AP225
    Posted Sep 10, 2013 06:48 PM
    Hi
    I´m deploying an AP225 and an AP135 together (same AP Group) on a controller 3400 (AOS 6.3.0.1).
    All is ok for the AP135.
    But the AP225 always goes to Monitor mode.
    What could be happening here?
    Thanks in advance.
    #3400
  • 2.  RE: Problem AP225
    Posted Sep 10, 2013 06:51 PM
    What's the configured country of operation?
  • 3.  RE: Problem AP225
    Posted Sep 10, 2013 07:02 PM
    The controller is configured for Mexico.
    Thanks.
  • 4.  RE: Problem AP225
    Posted Sep 10, 2013 07:12 PM
    Mexico is not yet a supported country for the AP-225. As a matter of fact, the product has no regulatory certs for Mexico yet and should not have shipped there. Who's your sales contact at Aruba?
  • 5.  RE: Problem AP225
    Posted Sep 10, 2013 07:13 PM
    The behavior you see is expected. Once certs are available, a SW update will enable AP-225 operation in Mexico.
  • 6.  RE: Problem AP225
    Posted Sep 10, 2013 07:21 PM
    This is only a test for our labs.
    And then I should wait for the update.
    Thank you.
  • 7.  RE: Problem AP225
    Posted Sep 10, 2013 07:25 PM
    In a lab you could test after setting the country code to a supported one (US for example), but for a real deployment that would be illegal.
  • 8.  RE: Problem AP225
    Posted Sep 10, 2013 07:30 PM
    Ok, then I will change the Country Code.
    And thanks for the advice.
    Regards.
  • 9.  RE: Problem AP225
    Posted Jan 29, 2014 09:14 PM
    What about now in 2014 with AOS 6.3.1.2AOS that is in production recommended by our Technical Support Engineer in Mexico)?.
    I have a similar thing with an open case since some months ago and seems like a M3MK1 (6000 controller) module is hardware restricted.
