Wired Intelligent Edge
Problem between two Aruba 2930F LACP Trunks
This thread has been viewed 19 times
  • 1.  Problem between two Aruba 2930F LACP Trunks
    Posted Dec 11, 2019 04:33 PM
    I have 4 Aruba 2930F, two in VSF on one side, and the other two in VSF on the other side.
    I connect both VSFs via two ports in LACP Static Trunk.
    Eventually I have connection problems in one of the VSFs.
    Apparently, for some reason it seems that the LACP trunks lose and reconnect.
    Could someone tell me if it's a configuration problem or if it's a hardware problem?
    I attach the logs of events and configuration of each one.
    Log events:
    I 12/11/19 06:40:02 00828 lldp: ST2-CMDR: PVID mismatch on port 1/10(VID
                100)with peer device port 1/1(VID 10)(14401)
    I 12/11/19 06:40:07 00828 lldp: ST2-CMDR: PVID mismatch on port 1/1(VID 10)with
                peer device port 1/10(VID 100)(14405)
    I 12/11/19 06:40:51 00828 lldp: ST2-CMDR: PVID mismatch on port 1/7(VID 70)with
                peer device port Ethernet0/0/4(VID 101)(14398)
    I 12/11/19 06:41:28 00828 lldp: ST2-CMDR: PVID mismatch on port 1/9(VID 90)with
                peer device port Ethernet0/0/5(VID 102)(14406)
    W 12/11/19 15:41:37 05220 activate: ST2-CMDR: Unable to resolve the Activate
                server address device.arubanetworks.com.
    I 12/11/19 17:49:04 00077 ports: ST2-CMDR: port 2/22 in Trk1 is now off-line
    I 12/11/19 17:49:04 00079 ports: ST2-CMDR: trunk Trk1 is now inactive
    I 12/11/19 17:49:04 00077 ports: ST2-CMDR: port 1/22 in Trk1 is now off-line
    I 12/11/19 17:49:11 00077 ports: ST1-STBY: port 2/22 in Trk1 is now off-line
    I 12/11/19 17:49:11 00079 ports: ST1-STBY: trunk Trk1 is now inactive
    I 12/11/19 17:49:11 00077 ports: ST1-STBY: port 1/22 in Trk1 is now off-line
    I 12/11/19 17:49:07 00435 ports: ST2-CMDR: port 1/22 is Blocked by LACP
    I 12/11/19 17:49:07 00435 ports: ST2-CMDR: port 2/22 is Blocked by LACP
    I 12/11/19 17:49:13 00435 ports: ST1-STBY: port 1/22 is Blocked by LACP
    I 12/11/19 17:49:14 00435 ports: ST1-STBY: port 2/22 is Blocked by LACP
    I 12/11/19 17:49:13 00078 ports: ST2-CMDR: trunk Trk1 is now active
    I 12/11/19 17:49:13 00076 ports: ST2-CMDR: port 2/22 in Trk1 is now on-line
    I 12/11/19 17:49:13 00076 ports: ST2-CMDR: port 1/22 in Trk1 is now on-line
    I 12/11/19 17:49:19 00078 ports: ST1-STBY: trunk Trk1 is now active
    I 12/11/19 17:49:19 00076 ports: ST1-STBY: port 2/22 in Trk1 is now on-line
    I 12/11/19 17:49:20 00076 ports: ST1-STBY: port 1/22 in Trk1 is now on-line
    I 12/11/19 17:50:39 00077 ports: ST2-CMDR: port 2/21 in Trk2 is now off-line
    I 12/11/19 17:50:39 00079 ports: ST2-CMDR: trunk Trk2 is now inactive
    I 12/11/19 17:50:39 00077 ports: ST2-CMDR: port 1/21 in Trk2 is now off-line
    I 12/11/19 17:50:46 00077 ports: ST1-STBY: port 2/21 in Trk2 is now off-line
    I 12/11/19 17:50:46 00079 ports: ST1-STBY: trunk Trk2 is now inactive
    I 12/11/19 17:50:46 00077 ports: ST1-STBY: port 1/21 in Trk2 is now off-line
    I 12/11/19 17:50:41 00435 ports: ST2-CMDR: port 1/21 is Blocked by LACP
    I 12/11/19 17:50:41 00435 ports: ST2-CMDR: port 2/21 is Blocked by LACP
    I 12/11/19 17:50:47 00435 ports: ST1-STBY: port 1/21 is Blocked by LACP
    I 12/11/19 17:50:48 00435 ports: ST1-STBY: port 2/21 is Blocked by LACP
    I 12/11/19 17:50:47 00078 ports: ST2-CMDR: trunk Trk2 is now active
    I 12/11/19 17:50:47 00076 ports: ST2-CMDR: port 2/21 in Trk2 is now on-line
    I 12/11/19 17:50:47 00076 ports: ST2-CMDR: port 1/21 in Trk2 is now on-line
    I 12/11/19 17:50:53 00078 ports: ST1-STBY: trunk Trk2 is now active
    I 12/11/19 17:50:53 00076 ports: ST1-STBY: port 2/21 in Trk2 is now on-line
    I 12/11/19 17:50:54 00076 ports: ST1-STBY: port 1/21 in Trk2 is now on-line
    I 12/11/19 17:50:53 00077 ports: ST2-CMDR: port 2/21 in Trk2 is now off-line
    I 12/11/19 17:50:53 00079 ports: ST2-CMDR: trunk Trk2 is now inactive
    I 12/11/19 17:50:53 00077 ports: ST2-CMDR: port 1/21 in Trk2 is now off-line
    I 12/11/19 17:50:59 00077 ports: ST1-STBY: port 2/21 in Trk2 is now off-line
    I 12/11/19 17:50:59 00079 ports: ST1-STBY: trunk Trk2 is now inactive
    I 12/11/19 17:50:59 00077 ports: ST1-STBY: port 1/21 in Trk2 is now off-line
    I 12/11/19 17:50:57 00435 ports: ST2-CMDR: port 1/21 is Blocked by LACP
    I 12/11/19 17:50:57 00435 ports: ST2-CMDR: port 2/21 is Blocked by LACP
    I 12/11/19 17:51:04 00435 ports: ST1-STBY: port 1/21 is Blocked by LACP
    I 12/11/19 17:51:04 00435 ports: ST1-STBY: port 2/21 is Blocked by LACP
    I 12/11/19 17:51:00 00078 ports: ST2-CMDR: trunk Trk2 is now active
    I 12/11/19 17:51:00 00076 ports: ST2-CMDR: port 1/21 in Trk2 is now on-line
    I 12/11/19 17:51:00 00076 ports: ST2-CMDR: port 2/21 in Trk2 is now on-line
    I 12/11/19 17:51:07 00078 ports: ST1-STBY: trunk Trk2 is now active
    I 12/11/19 17:51:07 00076 ports: ST1-STBY: port 1/21 in Trk2 is now on-line
    I 12/11/19 17:51:07 00076 ports: ST1-STBY: port 2/21 in Trk2 is now on-line
    I 12/11/19 17:51:09 00077 ports: ST2-CMDR: port 2/22 in Trk1 is now off-line
    I 12/11/19 17:51:16 00077 ports: ST1-STBY: port 2/22 in Trk1 is now off-line
    I 12/11/19 17:51:09 00079 ports: ST2-CMDR: trunk Trk1 is now inactive
    I 12/11/19 17:51:09 00077 ports: ST2-CMDR: port 1/22 in Trk1 is now off-line
    I 12/11/19 17:51:16 00079 ports: ST1-STBY: trunk Trk1 is now inactive
    I 12/11/19 17:51:16 00077 ports: ST1-STBY: port 1/22 in Trk1 is now off-line
    I 12/11/19 17:51:11 00435 ports: ST2-CMDR: port 2/22 is Blocked by LACP
    I 12/11/19 17:51:12 00435 ports: ST2-CMDR: port 1/22 is Blocked by LACP
    I 12/11/19 17:51:18 00435 ports: ST1-STBY: port 2/22 is Blocked by LACP
    I 12/11/19 17:51:18 00435 ports: ST1-STBY: port 1/22 is Blocked by LACP
    I 12/11/19 17:51:14 00078 ports: ST2-CMDR: trunk Trk1 is now active
    I 12/11/19 17:51:14 00076 ports: ST2-CMDR: port 1/22 in Trk1 is now on-line
    I 12/11/19 17:51:14 00076 ports: ST2-CMDR: port 2/22 in Trk1 is now on-line
    I 12/11/19 17:51:21 00078 ports: ST1-STBY: trunk Trk1 is now active
    I 12/11/19 17:51:21 00076 ports: ST1-STBY: port 1/22 in Trk1 is now on-line
    I 12/11/19 17:51:21 00076 ports: ST1-STBY: port 2/22 in Trk1 is now on-line
    I 12/11/19 17:51:18 00077 ports: ST2-CMDR: port 2/21 in Trk2 is now off-line
    I 12/11/19 17:51:18 00079 ports: ST2-CMDR: trunk Trk2 is now inactive
    I 12/11/19 17:51:18 00077 ports: ST2-CMDR: port 1/21 in Trk2 is now off-line
    I 12/11/19 17:51:24 00077 ports: ST1-STBY: port 2/21 in Trk2 is now off-line
    I 12/11/19 17:51:24 00079 ports: ST1-STBY: trunk Trk2 is now inactive
    I 12/11/19 17:51:24 00077 ports: ST1-STBY: port 1/21 in Trk2 is now off-line
    I 12/11/19 17:51:20 00435 ports: ST2-CMDR: port 2/22 is Blocked by LACP
    I 12/11/19 17:51:20 00435 ports: ST2-CMDR: port 1/22 is Blocked by LACP
    I 12/11/19 17:51:20 00079 ports: ST2-CMDR: trunk Trk1 is now inactive
    I 12/11/19 17:51:20 00002 vlan: ST2-CMDR: VL 80 virtual LAN disabled
    I 12/11/19 17:51:27 00435 ports: ST1-STBY: port 2/22 is Blocked by LACP
    I 12/11/19 17:51:27 00435 ports: ST1-STBY: port 1/22 is Blocked by LACP
    I 12/11/19 17:51:27 00079 ports: ST1-STBY: trunk Trk1 is now inactive
    I 12/11/19 17:51:21 00435 ports: ST2-CMDR: port 1/21 is Blocked by LACP
    I 12/11/19 17:51:21 00435 ports: ST2-CMDR: port 2/21 is Blocked by LACP
    I 12/11/19 17:51:28 00435 ports: ST1-STBY: port 1/21 is Blocked by LACP
    I 12/11/19 17:51:28 00435 ports: ST1-STBY: port 2/21 is Blocked by LACP
    I 12/11/19 17:51:22 00078 ports: ST2-CMDR: trunk Trk1 is now active
    I 12/11/19 17:51:22 00076 ports: ST2-CMDR: port 1/22 in Trk1 is now on-line
    I 12/11/19 17:51:22 00001 vlan: ST2-CMDR: VL 80 virtual LAN enabled
    I 12/11/19 17:51:29 00078 ports: ST1-STBY: trunk Trk1 is now active
    I 12/11/19 17:51:29 00076 ports: ST1-STBY: port 1/22 in Trk1 is now on-line
    I 12/11/19 17:51:23 00076 ports: ST2-CMDR: port 2/22 in Trk1 is now on-line
    I 12/11/19 17:51:24 00078 ports: ST2-CMDR: trunk Trk2 is now active
    I 12/11/19 17:51:24 00076 ports: ST2-CMDR: port 1/21 in Trk2 is now on-line
    I 12/11/19 17:51:24 00076 ports: ST2-CMDR: port 2/21 in Trk2 is now on-line
    I 12/11/19 17:51:30 00076 ports: ST1-STBY: port 2/22 in Trk1 is now on-line
    I 12/11/19 17:51:31 00078 ports: ST1-STBY: trunk Trk2 is now active
    I 12/11/19 17:51:31 00076 ports: ST1-STBY: port 1/21 in Trk2 is now on-line
    I 12/11/19 17:51:31 00076 ports: ST1-STBY: port 2/21 in Trk2 is now on-line
    I 12/11/19 17:53:43 00077 ports: ST2-CMDR: port 2/21 in Trk2 is now off-line
    I 12/11/19 17:53:43 00079 ports: ST2-CMDR: trunk Trk2 is now inactive
    I 12/11/19 17:53:43 00077 ports: ST2-CMDR: port 1/21 in Trk2 is now off-line
    I 12/11/19 17:53:50 00077 ports: ST1-STBY: port 2/21 in Trk2 is now off-line
    I 12/11/19 17:53:50 00079 ports: ST1-STBY: trunk Trk2 is now inactive
    I 12/11/19 17:53:50 00077 ports: ST1-STBY: port 1/21 in Trk2 is now off-line
    I 12/11/19 17:53:46 00435 ports: ST2-CMDR: port 2/21 is Blocked by LACP
    I 12/11/19 17:53:46 00435 ports: ST2-CMDR: port 1/21 is Blocked by LACP
    I 12/11/19 17:53:52 00435 ports: ST1-STBY: port 2/21 is Blocked by LACP
    I 12/11/19 17:53:52 00435 ports: ST1-STBY: port 1/21 is Blocked by LACP
    I 12/11/19 17:53:49 00078 ports: ST2-CMDR: trunk Trk2 is now active
    I 12/11/19 17:53:49 00076 ports: ST2-CMDR: port 1/21 in Trk2 is now on-line
    I 12/11/19 17:53:49 00076 ports: ST2-CMDR: port 2/21 in Trk2 is now on-line
    I 12/11/19 17:53:55 00078 ports: ST1-STBY: trunk Trk2 is now active
    I 12/11/19 17:53:55 00076 ports: ST1-STBY: port 1/21 in Trk2 is now on-line
    I 12/11/19 17:53:55 00076 ports: ST1-STBY: port 2/21 in Trk2 is now on-line
    I 12/11/19 17:53:58 00435 ports: ST2-CMDR: port 2/21 is Blocked by LACP
    I 12/11/19 17:53:58 00435 ports: ST2-CMDR: port 1/21 is Blocked by LACP
    I 12/11/19 17:53:58 00079 ports: ST2-CMDR: trunk Trk2 is now inactive
    I 12/11/19 17:54:05 00435 ports: ST1-STBY: port 2/21 is Blocked by LACP
    I 12/11/19 17:54:05 00435 ports: ST1-STBY: port 1/21 is Blocked by LACP
    I 12/11/19 17:54:05 00079 ports: ST1-STBY: trunk Trk2 is now inactive
    I 12/11/19 17:54:00 00078 ports: ST2-CMDR: trunk Trk2 is now active
    I 12/11/19 17:54:00 00076 ports: ST2-CMDR: port 1/21 in Trk2 is now on-line
    I 12/11/19 17:54:06 00078 ports: ST1-STBY: trunk Trk2 is now active
    I 12/11/19 17:54:06 00076 ports: ST1-STBY: port 1/21 in Trk2 is now on-line
    I 12/11/19 17:54:01 00076 ports: ST2-CMDR: port 2/21 in Trk2 is now on-line
    I 12/11/19 17:54:08 00076 ports: ST1-STBY: port 2/21 in Trk2 is now on-line
    VSF 1 config
    Running configuration:
    ; hpStack_WC Configuration Editor; Created on release #WC.16.04.0014
    ; Ver #11:10.9b.3f.bf.bb.ef.7c.59.fc.6b.fb.9f.fc.ff.ff.37.ef:bc
    hostname "Core-HV-Commander"
    vsf
       enable domain 9000
       member 1
          type "JL259A" mac-address 9cdc71-37da40
          priority 255
          link 2 1/23-1/24
          link 2 name "I-Link1_2"
          exit
       member 2
          type "JL259A" mac-address 9cdc71-362fe0
          priority 128
          link 2 2/23-2/24
          link 2 name "I-Link2_2"
          exit
       port-speed 1g
       exit
    aruba-central disable
    trunk 1/1-1/2,2/1-2/2 trk1 lacp
    trunk 1/3-1/4,2/3-2/4 trk2 lacp
    trunk 1/5-1/6,2/5-2/6 trk3 lacp
    trunk 1/7-1/8,2/7-2/8 trk4 lacp
    trunk 1/9,2/9 trk5 lacp
    trunk 1/10,2/10 trk6 lacp
    trunk 1/21,2/21 trk50 lacp
    trunk 1/22,2/22 trk60 lacp
    include-credentials
    password manager user-name "manager" sha1
     "6f2f6aad0e3d08acaa56fcae9ead3eb7ad259ed6"
    time timezone -3
    interface 1/1
       lacp key 100
       exit
    interface 1/2
       lacp key 100
       exit
    interface 1/3
       lacp key 200
       exit
    interface 1/4
       lacp key 200
       exit
    interface 1/5
       lacp key 300
       exit
    interface 1/6
       lacp key 300
       exit
    interface 1/7
       lacp key 400
       exit
    interface 1/8
       lacp key 400
       exit
    interface 1/9
       lacp key 500
       exit
    interface 1/10
       lacp key 600
       exit
    interface 1/11
       lacp key 700
       exit
    interface 1/22
       lacp key 9999
       exit
    interface 2/1
       lacp key 100
       exit
    interface 2/2
       lacp key 100
       exit
    interface 2/3
       lacp key 200
       exit
    interface 2/4
       lacp key 200
       exit
    interface 2/5
       lacp key 300
       exit
    interface 2/6
       lacp key 300
       exit
    interface 2/7
       lacp key 400
       exit
    interface 2/8
       lacp key 400
       exit
    interface 2/9
       lacp key 500
       exit
    interface 2/10
       lacp key 600
       exit
    interface 2/11
       lacp key 700
       exit
    interface 2/22
       lacp key 9999
       exit
    snmp-server community "public" unrestricted
    snmpv3 engineid "00:00:00:0b:00:00:9c:dc:71:37:da:43"
    vlan 1
       name "DEFAULT_VLAN"
       untagged 1/11-1/20,1/25-1/28,2/11-2/20,2/25-2/28,Trk1-Trk6,Trk50,Trk60
       ip address 10.250.250.16 255.255.255.0
       exit
    spanning-tree Trk1 priority 4
    spanning-tree Trk2 priority 4
    spanning-tree Trk3 priority 4
    spanning-tree Trk4 priority 4
    spanning-tree Trk5 priority 4
    spanning-tree Trk6 priority 4
    spanning-tree Trk50 priority 4
    spanning-tree Trk60 priority 4
    no tftp server
    no autorun
    no dhcp config-file-update
    no dhcp image-file-update
    VSF 2 config
    ; hpStack_WC Configuration Editor; Created on release #WC.16.05.0007
    ; Ver #12:08.1d.9b.3f.bf.bb.ef.7c.59.fc.6b.fb.9f.fc.ff.ff.37.ef:ba
    hostname "Enlaces-Commander"
    vsf
       enable domain 9001
       member 1
          type "JL259A" mac-address 08f1ea-4a4020
          priority 255
          link 1 1/23-1/24
          link 1 name "I-Link1_1"
          exit
       member 2
          type "JL259A" mac-address 548028-6068e0
          priority 128
          link 1 2/23-2/24
          link 1 name "I-Link2_1"
          exit
       port-speed 1g
       exit
    trunk 1/22,2/22 trk1 lacp
    trunk 1/21,2/21 trk2 lacp
    trunk 1/20,2/20 trk3 lacp
    no timesync
    time timezone -3
    interface 1/3
       speed-duplex 100-full
       exit
    interface 1/6
       exit
    interface 1/7
       exit
    interface 1/21
       lacp key 533
       exit
    interface 1/22
       lacp key 532
       exit
    interface 2/21
       lacp key 533
       exit
    interface 2/22
       lacp key 532
       exit
    snmp-server contact "Some user"
    vlan 1
       name "DEFAULT_VLAN"
       no untagged 1/1-1/18
       untagged 1/19,1/25-1/28,2/1-2/19,2/25-2/28,Trk1-Trk3
       ip address 10.250.250.18 255.255.255.0
       exit
    vlan 10
       name "VL 10"
       untagged 1/1
       tagged Trk1-Trk2
       no ip address
       exit
    vlan 20
       name "VL 20"
       untagged 1/2
       tagged Trk1-Trk2
       no ip address
       exit
    vlan 30
       name "VL 30"
       untagged 1/3
       tagged Trk1-Trk2
       no ip address
       exit
    vlan 40
       name "VL 40"
       untagged 1/4
       tagged Trk1-Trk2
       no ip address
       exit
    vlan 50
       name "VL 50"
       untagged 1/5
       tagged Trk1-Trk2
       no ip address
       exit
    vlan 60
       name "VL 60"
       untagged 1/6
       tagged Trk1-Trk2
       no ip address
       exit
    vlan 70
       name "VL 70"
       untagged 1/7
       tagged Trk1-Trk2
       no ip address
       exit
    vlan 80
       name "VL 80"
       untagged 1/8
       tagged Trk1-Trk2
       no ip address
       exit
    vlan 90
       name "VL 90"
       untagged 1/9
       tagged Trk1-Trk2
       no ip address
       exit
    vlan 100
       name "VL 100"
       untagged 1/10
       tagged Trk1-Trk2
       no ip address
       exit
    vlan 110
       name "VL 110"
       untagged 1/11
       tagged Trk1-Trk2
       no ip address
       exit
    vlan 120
       name "VL 120"
       untagged 1/12
       tagged Trk1-Trk2
       no ip address
       exit
    vlan 130
       name "VL 130"
       untagged 1/13
       tagged Trk1-Trk2
       no ip address
       exit
    vlan 140
       name "VL 140"   untagged 1/14
       tagged Trk1-Trk2
       no ip address
       exit
    vlan 150
       name "VL 150"
       untagged 1/15
       tagged Trk1-Trk2
       no ip address
       exit
    vlan 160
       name "VL 160"
       untagged 1/16
       tagged Trk1-Trk2
       no ip address
       exit
    vlan 170
       name "VL 170"
       untagged 1/17
       tagged Trk1-Trk2
       no ip address
       exit
    vlan 180
       name "VL 180"
       untagged 1/18
       tagged Trk1-Trk2
       no ip address
       exit
    no tftp server
    no autorun
    Thank you very much for your help.,
    Best regards,
    Gabriel
  • 2.  RE: Problem between two Aruba 2930F LACP Trunks
    MVP GURU
    Posted Dec 12, 2019 04:49 AM
    What do you have when use show lacp commands ?
    Do you have check vlan on trk interface ? (about PVID error)
  • 3.  RE: Problem between two Aruba 2930F LACP Trunks
    Posted Dec 12, 2019 08:02 AM
    Hi, thanks for reply.
    # show lacp
    LACP Trunk Port LACP Admin Oper
    Port Enabled Group Status Partner Status Key Key
    1/20 Active Trk3 Up Yes Success 0 534
    1/21 Active Trk2 Up Yes Success 533 533
    1/22 Active Trk1 Up Yes Success 532 532
    2/20 Active Trk3 Up Yes Success 0 534
    2/21 Active Trk2 Up Yes Success 533 533
    2/22 Active Trk1 Up Yes Success 532 532
    I really don't understand what caused the errors in trunks 1 and 2.
    Regard to PVID errors, I follow this guide to avoid the informational logs.
    https://community.arubanetworks.com/t5/Wired-Intelligent-Edge-Campus/How-To-Stop-PVID-Mismatch-Messages/ta-p/471996
  • 4.  RE: Problem between two Aruba 2930F LACP Trunks
    MVP GURU
    Posted Dec 12, 2019 08:09 AM
    it is possible to have show vlan port Trk1 detail for both switch (and also for trk 2 ) ?
  • 5.  RE: Problem between two Aruba 2930F LACP Trunks
    MVP GURU
    Posted Dec 13, 2019 07:58 AM
    @neok wrote: I have 4 Aruba 2930F, two in VSF on one side, and the other two in VSF on the other side.
    Which one please?
    Independently by the logical aggregation used to interconnect both VSFs you have a mismatching VLAN tagging configured...first VSF shows only Port Trunks (Trk1-Trk6,Trk50 and Trk60) as untagged members of VLAN 1 (Default)...instead second VSF shows a very different story...from what I see Trk1-Trk3 are untagged members of VLAN 1 (Default) and Trk1-Trk2 are tagged members of various VLANs (10, 20, 30 and so on...).
    Just considering Trk1 (if that is the uplink logical port used on both VSFs to interconnect them) that is highly asymmetrical and wrong...
    Do us a favour and paste the outputs of show lldp info remote-device (exectued on both VSF) and show vlan port Trk1 detail (executed on both VSF if - as written above - the Trk1 is the logical port used to interconnect both VSFs).
    Remember that Trk1 VLAN tagging on first VSF must match the Trk1 VLAN tagging on second VSF.
    What are you trying to achieve?
