Problem changing ALE password at first login
  • 1.  Problem changing ALE password at first login
    Posted May 25, 2014 05:46 AM
    Hi All,
    I thought I would play with the eval of ALE, so I have deployed it to our lab ESX host, but when I try change the password as required at first login i just get pushed back to the login.
    I can log in again with the default root/admin credentials but get prompted to change the password but not re type it as i would expect and then get sent back to the login.
    I have tried ALE-1.2.0.0-42792 & ALE-1.2.1.0-43065 but hit the same "issue" both with the ova and the iso
    does anyone know if there is a known issue and there is a special way to sort the first login out (possibly booting into single user mode)
    cheers
    Andy
  • 2.  RE: Problem changing ALE password at first login
    Posted May 27, 2014 03:03 PM
    hmm it should let you change it.
    Give me a few min and I will fire up a VM of 1.2.1
  • 3.  RE: Problem changing ALE password at first login
    Posted May 27, 2014 03:16 PM
    I just tried it on 1.2.1 and it worked. After you login with root/admin, it asks you for your current root password which is admin, then it will ask you to change it.
  • 4.  RE: Problem changing ALE password at first login
    Posted May 27, 2014 03:28 PM
    :smileyembarrassed:
    servers me right for not paying proper attention and trying to do 5 things at the same time..
  • 5.  RE: Problem changing ALE password at first login
    Posted May 27, 2014 03:54 PM
    No worries but you accepted the wrong solution :)
