Problem concerning the upgrade of airwave from 8.0.8.1 to 8.2.0.1
  • 1.  Problem concerning the upgrade of airwave from 8.0.8.1 to 8.2.0.1
    Posted Apr 19, 2016 04:16 AM
    Problem : I can't identify what is the problem
    The context : Airwave Interface is down
  • 2.  RE: Problem concerning the upgrade of airwave from 8.0.8.1 to 8.2.0.1
    Posted Apr 19, 2016 04:59 AM
    Any ideas ?
  • 3.  RE: Problem concerning the upgrade of airwave from 8.0.8.1 to 8.2.0.1
    Posted Apr 19, 2016 05:51 AM
    This is an overview from AMP-8.2.0.1-upgrade.log :
  • 4.  RE: Problem concerning the upgrade of airwave from 8.0.8.1 to 8.2.0.1
    Posted Apr 19, 2016 11:19 AM
    Problem solved : conflict of package Openldap.
  • 5.  RE: Problem concerning the upgrade of airwave from 8.0.8.1 to 8.2.0.1
    Posted Jul 18, 2016 10:25 PM
    I happen too.
    I don't know how to solve the problem.
    How to do System is normal working ?
    Please answer to me.
  • 6.  RE: Problem concerning the upgrade of airwave from 8.0.8.1 to 8.2.0.1
    Posted Jul 19, 2016 05:05 AM
    Hi Kim,
    Can you post the AMP-8.2.0.1-upgrade.log that i can help you to identify the problem ?
    in CLI :
    cd var/log/upgrade/
    cat AMP-8.2.0.1-upgrade.log
    and post it her
