Problem configuring Guest-access Captive Portal
  • 1.  Problem configuring Guest-access Captive Portal
    Posted Aug 30, 2013 06:11 PM
    I am having a problem with using the captive portal for guest access.  I get the captive portal page, but clicking through, I do not get successfully redirected to my site.  Instead, it often just sits at the "External Welcome Page" (http://10.100.0.110/cgi-bin/login)  The URL doesn't look right though.  The Controller IP is the main IP used, not the proper IP on the vlan.  Why would the page not be using the IP on that VLAN?
    It sort of seems to be working though, if I look at the user-table, but I still can't pass traffic.
    Here is when I'm newly connected to the wifi:
    (Aruba3600) #show user-table mac 00:16:cf:00:02:27
    Users
    IP MAC Name Role Age(d:h:m) Auth VPN link AP name Roaming Essid/Bssid/Phy Profile Forward mode Type
    10.200.1.61 00:16:cf:00:02:27 guest-logon 00:00:00 Library-L356-AP135 Wireless Concordia Guest/d8:c7:c8:80:db:58/a Concordia-Guest tunnel Win XP
    Here is when I've clicked through and it's 'spinning':
    Users
    10.200.1.61 00:16:cf:00:02:27 guest@concordia.ab.ca Concordia-Guest 00:00:02 Web Library-L356-AP135 Wireless Concordia Guest/d8:c7:c8:80:db:58/a Concordia-Guest tunnel Win XP
    Thanks in advance,
  • 2.  RE: Problem configuring Guest-access Captive Portal
    Posted Aug 30, 2013 07:36 PM
    you need to use the ip cp-redirect parameter to make sure the correct ip address on the correct VLAN is used....http://community.arubanetworks.com/t5/Command-of-the-Day/COTD-ip-cp-redirect-address/td-p/236
