Problem conneting to a external Postgre SQL
  • 1.  Problem conneting to a external Postgre SQL
    Posted Mar 20, 2018 11:25 AM
    Hello friends, I am trying to have a external Generic  SQL DB source of authentication but I am having the folllowing error when finishing my query.
    select CODUSUARIO as UserName, DTNASCIMENTO as user_password from CORPORERM.dbo.PPESSOA where CODUSUARIO =  '%{Authentication:Username}';
    The filter has been saved but has the following error:
    Invalid SQL syntax - FATAL: no entry in pg_hba.conf for machine "192.168.1.230" [My CPPM], user "postgres", database "CORPORERM", SSL disabled.
    I not sure if this file did exist on my CPPM too and where edit it, I already added the following line on it on my PostGRE server and I have others machine connecting  where is possible to query information from it.
    # TYPE  DATABASE        USER            ADDRESS                 METHOD
    host         all        all        0.0.0.0/0    trust
    # IPv4 local connections:
    host    all             all             127.0.0.1/32            md5
    host    all             postgres        192.168.1.230/32        trust
    any help is appreciated
    Thanks.
  • 2.  RE: Problem conneting to a external Postgre SQL
    Posted Mar 25, 2018 08:04 PM
    Still Stuck on this error.
    No idea where to look at, didn't find anything on the knowledge base (google rsrs) about this file and clearpass.
  • 3.  RE: Problem conneting to a external Postgre SQL
    Posted Mar 26, 2018 05:41 AM
    Can you please attach the auth source configuration (all tabs)?
  • 4.  RE: Problem conneting to a external Postgre SQL
    Posted Mar 26, 2018 12:39 PM
    Saravanan, bellow is the screenshoots of that you require.
    Attachment(s)
    zip
    problem-postgree.zip   1.81 MB 1 version
  • 5.  RE: Problem conneting to a external Postgre SQL
    Posted Mar 27, 2018 08:42 AM
    The error indicates that table "ppessoa" doesn't exisit and I see the actual table name is "PPESSOA".
    The unqouted identifiers are case insensitives (cast to lower case).
    https://www.postgresql.org/docs/current/static/sql-syntax-lexical.html#SQL-SYNTAX-IDENTIFIERS
    Can you try something like below and check the status?
    SELECT DTNASCIMENTO AS User_Password from "PPESSOA" where CODUSUARIO = '%{Authentication:Username}';
    or
    SELECT "DTNASCIMENTO" AS User_Password from "PPESSOA" where "CODUSUARIO" = '%{Authentication:Username}';
    I also noticed the colomun "DTNASCIMENTO" type is integer (numeric). ClearPass may try to validate the User_Password" as string. So, you may need to convert password from Integer to String.
    SELECT CAST("DTNASCIMENTO" as VARCHAR(50)) AS User_Password from "PPESSOA" where "CODUSUARIO" = '%{Authentication:Username}';
  • 6.  RE: Problem conneting to a external Postgre SQL
    Posted Mar 27, 2018 05:24 PM
    Ok, now some kind of progress....
    in attached is the new error, the red one is still showing up, but on my server side/logs I am not getting any error anymore about syntax(i did learn where to look at).
    I adapted the query based on this post here
    https://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/How-To-Setup-External-SQL-Filter-Queries-for-Authentication-in/ta-p/187252
    My deployment is a replica of what I am doing on my client, just to be clear.
    I will be wating for help, still stuck, as you can see I even add a new columm as varchar[50] just to be sure.
    Attachment(s)
    zip
    postgres.zip   1.01 MB 1 version
  • 7.  RE: Problem conneting to a external Postgre SQL
    Posted Apr 03, 2018 12:41 PM
    The server is reproting that it is unable to find the user and I see the user in the column "CODUSUARIO" is "3.0". You may need to try the matching string.
    May I suggest to open a TAC case? This needs debugging, if the username 3.0 is not working.
  • 8.  RE: Problem conneting to a external Postgre SQL
    Posted Apr 04, 2018 03:19 PM
    Request log details for session: R00000008-01-5ac51e12
    Time Message
    2018-04-04 15:48:50,728[Th 12 Req 8 SessId R00000008-01-5ac51e12] INFO RadiusServer.Radius - rlm_service: Starting Service Categorization - 9:205:f0d7aa9d2f09
    2018-04-04 15:48:50,732[RequestHandler-1-0x7fa189f6e700 r=psauto-1522863313-18 h=127 r=R00000008-01-5ac51e12] INFO Core.ServiceReqHandler - Service classification result = TEST_radius-POSTGRES
    2018-04-04 15:48:50,733[Th 12 Req 8 SessId R00000008-01-5ac51e12] INFO RadiusServer.Radius - Service Categorization time = 5 ms
    2018-04-04 15:48:50,733[Th 12 Req 8 SessId R00000008-01-5ac51e12] INFO RadiusServer.Radius - rlm_service: The request has been categorized into service "TEST_radius-POSTGRES"
    2018-04-04 15:48:50,733[Th 12 Req 8 SessId R00000008-01-5ac51e12] INFO RadiusServer.Radius - rlm_sql: searching for user testuser in Sql:192.168.1.14
    2018-04-04 15:48:50,753[Th 12 Req 8 SessId R00000008-01-5ac51e12] ERROR RadiusServer.Radius - rlm_sql_unixodbc: sql state - 07005, sql error - unixODBC]Bindings were not allocated properly.
    2018-04-04 15:48:50,753[Th 12 Req 8 SessId R00000008-01-5ac51e12] ERROR RadiusServer.Radius - rlm_sql_unixodbc: SQL down 07005 unixODBC]Bindings were not allocated properly.
    2018-04-04 15:48:50,753[Th 12 Req 8 SessId R00000008-01-5ac51e12] INFO RadiusServer.Radius - rlm_sql_unixodbc: rlm_sql will attempt to reconnect
    2018-04-04 15:48:50,770[Th 12 Req 8 SessId R00000008-01-5ac51e12] ERROR RadiusServer.Radius - rlm_sql_unixodbc: sql state - HY010, sql error - unixODBC]Driver Manager]Function sequence error
    2018-04-04 15:48:50,770[Th 12 Req 8 SessId R00000008-01-5ac51e12] ERROR RadiusServer.Radius - rlm_sql_unixodbc: SQL down HY010 unixODBC]Driver Manager]Function sequence error
    2018-04-04 15:48:50,770[Th 12 Req 8 SessId R00000008-01-5ac51e12] INFO RadiusServer.Radius - rlm_sql_unixodbc: rlm_sql will attempt to reconnect
    2018-04-04 15:48:50,770[Th 12 Req 8 SessId R00000008-01-5ac51e12] ERROR RadiusServer.Radius - rlm_sql (authsrc_3001): failed after re-connect
    2018-04-04 15:48:50,770[Th 12 Req 8 SessId R00000008-01-5ac51e12] INFO RadiusServer.Radius - rlm_auth_check: Auth-Type not set.
    2018-04-04 15:48:50,770[Th 12 Req 8 SessId R00000008-01-5ac51e12] ERROR RadiusServer.Radius - rlm_auth_check: Auth-Type not set or authentication methods have not been configured. Rejecting it.
