Problem getting internet access
  • 1.  Problem getting internet access
    Posted Sep 02, 2019 07:19 AM
    We have 2x IAP-315 in a cluster where we want to create seperate SSID's for 12 rooms
    Both AP's are connected to a Aruba 2530-8G switch
    Router has IP 192.168.1.1
    Have created a SSID with virtual controller managed Client IP assignment. Chosen Custom Client VLAN Assignment and then created a new local DHCP scope. (Local, L2)
    Ex network 172.16.110.0 / 255.255.255.0
    Default router and DNS: 192.168.1.1
    VLAN ID: 10 ( have tagged ports on switch - both ports connected to AP's and unlink port to router)
    Not quite sure what to enter in VLAN IP and subnet mask
    Tried with 172.16.110.1 / 255.255.255.0 and other things but it doesn't matter
    Client connects without issues to SSID and gets correct IP assignments but cannot access internet
    Have a missed something or should it be set up in another way
  • 2.  RE: Problem getting internet access
    Posted Sep 05, 2019 03:49 AM
    with Local-L2, the IAP will provide DHCP sevice but the default gateway is outside on the same subnet. so if your outside gateway is 192.168.1.1 then your dhcp scope in Local-L2 can be 192.168.1.0/24
    regards
  • 3.  RE: Problem getting internet access
    Posted Sep 05, 2019 03:59 AM
    Sorry but that does make sense to me when you have to put in a vlan
    Do you mean that every network I make should then have the same dhcp scope but different vlans
    Med venlig hilsen
    Kim Alsted
    Teknisk Direktør
    IT-Kompagniet
  • 4.  RE: Problem getting internet access
    Posted Sep 05, 2019 05:01 AM
    remember the default gateway for a subnet should be on that subnet. for example for subnet 172.16.1.0/24, the defult gateway can be 172.16.1.1 but it can not be 192.168.1.1
