Problem: Guest available to access CPPM over CN certificate
  • 1.  Problem: Guest available to access CPPM over CN certificate
    Posted Oct 21, 2016 11:37 AM
    Hello folks.
    I have a a captive portal over CPPM and a SSL certificate in order to get a HTTPS portal. The dhcp scoop is manage by the controller and it is nat to a costumer firewall for internet.
    The problem is that the users connected in SSID guest (captive portal) are available to get CPPM page over the CN.
    SSL certificate: CN: example.company.com
    Name of server: CPPM
    Dns of CPPM: internal
    Scoop guest: over controller
    Dns: google
    Captive portal page: example.company.com/guest/registre.php
    If the guest put on the browser : example.company.com after get access to internet is avaible to access CPPM
    How I can fix this big hole of security?
    Hopping yo can help me.
    Best regarda.
  • 2.  RE: Problem: Guest available to access CPPM over CN certificate
    Posted Oct 21, 2016 02:36 PM
    Use the application ACLs under the server's configuration section.
  • 3.  RE: Problem: Guest available to access CPPM over CN certificate
    Posted Nov 02, 2016 10:40 AM
    It´s not working! is this acl aplication works only with the IP management? or works on the data IP too?
