Problem importing plan on airwave virtualRF
  • 1.  Problem importing plan on airwave virtualRF
    Posted Oct 24, 2014 06:37 PM
    Hello everyone,
    I'm doing plan for wifi in the VisualRF plan standalone software because it has more option and easier to use.
    Local Quickview
    Version:Build Date:Java Runtime Version: VisualRF Engine Version:VisualRF Engine Build:VisualRF Engine Database:VisualRF Data Path:VisualRF Plan Static:
    7.7.rc1 (build: 448)
    2014-05-19 13:09 PDT
    1.6.0_22
    7.7.0
    80766
    80766
    C:\Program Files (x86)\VisualRF Plan\data
    80766
    I'm having problem when importing the plan into airwave VisualRf. The background OR wall is misplace and they are out of "sync". I'm uploading and exemple of the problem.
    I try the two way the software offer to export. No cigar.
    Anyone ever had the same problem?
    Is there a way to move the background image once imported in the airwave app?
    Thank you very much
  • 2.  RE: Problem importing plan on airwave virtualRF
    Posted Oct 28, 2014 12:18 PM
    what version of airwave do you use?
  • 3.  RE: Problem importing plan on airwave virtualRF
    Posted Oct 28, 2014 12:21 PM
    I think this is a browser problem with html5...
    use chrome and taka a look on your plan. Chrome works better with it...
    On Airwave version 8.0.4.1 or 8.0.5 I think the problem is fixed...
    give kodos if it works :-)
  • 4.  RE: Problem importing plan on airwave virtualRF
    Posted Oct 28, 2014 12:22 PM
    for Airwave upgrade use on comandline the command:
    amp_upgrade
  • 5.  RE: Problem importing plan on airwave virtualRF
    Posted Oct 29, 2014 05:05 PM
    Currently on airwave 8.0.4.1
    Will try to import the plan on Chrome soon.
    I'll give some feedback ASAP
    Thank you very much for your help!
  • 6.  RE: Problem importing plan on airwave virtualRF
    Posted Nov 07, 2014 08:05 PM
    Tested with Chrome. No cigar.
    I'm waiting for airwave update. Many things happening and can't do it right away.
  • 7.  RE: Problem importing plan on airwave virtualRF
    Posted Nov 21, 2014 04:51 PM
    Airwabe has been updated to 8.0.5 and the problem still happend.
    We can select all the wall in same time. is there a way to moved them all as one?
    I would hate to redo all building in the web version of VRF.
  • 8.  RE: Problem importing plan on airwave virtualRF
    Posted Dec 09, 2014 02:09 PM
    I still haven't found a solution.
    Anyone can help?
  • 9.  RE: Problem importing plan on airwave virtualRF
    Posted Dec 09, 2014 05:33 PM
    Suggest opening a case for this with TAC.  We've resolved several issues in the AirWave VisualRF.
